[mapguide-users] Raster Tiling - rasterconfig.php
Saso
saso at sl-king.si
Wed Jan 16 03:38:25 EST 2008
In MGOS 1.2 with FDO 3.2.3 i have used raster config file utility:
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes .
Problem is, that only part from 80 raster images (tif/tfw) are shown in
mgos, if i use config file utility.
In enlclosed config file where you can see only 2 images defined, the other
4 are not in config.xml.
http://www.nabble.com/file/p14874242/raster%2Btile%2Bconfig.txt
raster+tile+config.txt
If i don't use config file utility, all images are shown in mgos.
TFW files from images that are and aren't in config.xml looks similar.
What could be the reason, raster tile index not including all image files?
Thanks, Saso
SL-King
View this message in context: http://www.nabble.com/Raster-Tiling---rasterconfig.php-tp14874242s16610p14874242.html
