[mapguide-users] Using FUSION with base map providers
Paul Spencer pagameba at gmail.com
Wed Jan 16 21:40:53 EST 2008
Hi Suja,
it is technically possible to make it work but not directly supported
through the application definition.  It requires custom javascript
code and a good understanding of the internal API to attempt it.  At
this time, I am not prepared to recommend it or describe how to do it.
Cheers
Paul
On 15-Jan-08, at 10:04 AM, Suja Sudhan wrote:
> Hi Everyone,
> Can I have your views on how easy is it to use FUSION with different
> base
> map providers like google maps, yahoo map, etc.? Can I have some
> samples, if
> available?
> Thanks,
> Suja
> View this message in context: http://www.nabble.com/Using-FUSION-with-base-map-providers-tp14841414s16610p14841414.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
