[mapguide-users] Fusion - 'Resource not found Error'
Paul Spencer pagameba at gmail.com
Wed Jan 16 22:25:03 EST 2008
Suja,
Note that the path is case sensitive.  In particular, Library has a
capital L and MapDefinition has a capital M and D.  If the folder or
map name have capitals in Studio, then they have to be appropriately
capitalized in the ApplicationDefinition file.
Cheers
Paul
On 8-Jan-08, at 8:18 AM, Suja Sudhan wrote:
> Hi All,
> I recently installed Fusion and the samples work fine with the
> sheboygan
> mapdefinition. If I change the ApplicationDefinition.xml to load
> other maps,
> I get an error saying 'Failed to load requested map - Resource
> (points to my
> mapdefinition eg. library://test/test.mapdefinition) not found'. The
> mapdefinition is valid and can be previewed using Studio.
> Can someone point to what I am missing or what might have gone wrong?
> Thanks for your time.
> Suja
> View this message in context: http://www.nabble.com/Fusion---%27Resource-not-found-Error%27-tp14689343s16610p14689343.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
