[mapguide-users] Working around/Disabling FastCGI in MGOS 1.2
Ronnie Louie ronnie.louie at autodesk.com
Mon Jan 28 19:28:03 EST 2008
Hi Crispin,
MGOS 2.0 will only support CGI, ISAPI extension, and Apache module.  FastCGI support is removed due to a number issues with the technology.  By directly using API specific for IIS or Apache webservers, stability and performance improvement is expected since we eliminate any overhead created from having another interface sitting between MGOS and the webserver.
Ronnie
-----Original Message-----
From: Crispin @ 1Spatial [mailto:Crispin.Hoult at 1Spatial.com]
Sent: Monday, January 28, 2008 8:40 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Working around/Disabling FastCGI in MGOS 1.2
... also an additional question that has been in my mind for ages if there is
an FCGI expert replying ...
MS have now released the FastCGI extension thing for IIS 6 and built support
right into IIS7 on Win2008 - was FCGI actually a better solution that just
didn't work 100% on IIS or is ISAPI superior regardless?
Did FCGI die in MGOS 2.0 or is it a configuration option like the renderer?
Thanks people,
 Crispin
View this message in context: http://www.nabble.com/Working-around-Disabling-FastCGI-in-MGOS-1.2-tp14794134s16610p14835223.html
