[mapguide-users] New User Help (.net)
cgrell
craig.grell at talus-tech.com
Wed Jan 30 09:55:48 EST 2008
Thank you for the reply.
In the end I was putting the sample in the wrong location which ment it was
calling the mapviewerajax from the wrong location.
Now I am working with a demo MapGuide Studio and trying to get a simple .shp
file loaded.
The data and layer were loaded fine. The layer's preview shows what I was
expecting.
I have tried to create a map based on the layer and the map preview shows
nothing.
Does anyone have some tips that could help me with this?
Thank you
Kenneth, GEOGRAF A/S wrote:
> As I recall, you must also install a demo website (the MGP package only
> has the data for the demo).
> I believe the correct package is named "DotNetViewerSample".
> You might get away with running this:
> http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fSamples%2fSheboygan%2fLayouts%2fSheboyganAsp.WebLayout&USERNAME=Anonymous&PASSWORD=
> You will also need an editor for the data.
> You can request a trial of MapGuide Studio from Autodesk, and they will
> send a 30 (60?) day trial CD by mail.
> Regards, Kenneth, GEOGRAF A/S
> cgrell skrev:
>> I have been struggling with this for weeks now and am very stuck.
>> I have installed the MapGuide Server 1.2.0, Web Server Extenstions 1.2.0
>> using .net
>> I can login to the admin at http://localhost/mapguide/mapadmin/login.php
>> and
>> loaded the sample file Sheboygan.mgp
>> When I go to http://localhost/mapguide/mapviewernet/gettingstarted.aspx I
>> get the following error
>> Invalid repository type. Exception occurred in method
>> MgResourceIdentifier.ParseIdentifier at line 440 in file
>> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\common\platformbase\Services/ResourceIdentifier.cpp
>> When i go to http://localhost/mapguide/mapviewernet/ajaxviewer.aspx i get
>> the following error
>> An unclassified exception occurred.
>> An unclassified exception occurred. Exception occurred in method
>> new_MgResourceIdentifier at line 681 in file .\MgApi_wrap.cpp
>> What am I missing?
>> Thank you
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/New-User-Help-%28.net%29-tp15147370s16610p15183210.html
