[mapguide-users] New User Help (.net)
Kenneth, GEOGRAF A/S
ks at geograf.dk
Tue Jan 29 04:53:13 EST 2008
As I recall, you must also install a demo website (the MGP package only
has the data for the demo).
I believe the correct package is named "DotNetViewerSample".
You might get away with running this:
http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fSamples%2fSheboygan%2fLayouts%2fSheboyganAsp.WebLayout&USERNAME=Anonymous&PASSWORD=
You will also need an editor for the data.
You can request a trial of MapGuide Studio from Autodesk, and they will
send a 30 (60?) day trial CD by mail.
Regards, Kenneth, GEOGRAF A/S
cgrell skrev:
> I have been struggling with this for weeks now and am very stuck.
> I have installed the MapGuide Server 1.2.0, Web Server Extenstions 1.2.0
> using .net
> I can login to the admin at http://localhost/mapguide/mapadmin/login.php and
> loaded the sample file Sheboygan.mgp
> When I go to http://localhost/mapguide/mapviewernet/gettingstarted.aspx I
> get the following error
> Invalid repository type. Exception occurred in method
> MgResourceIdentifier.ParseIdentifier at line 440 in file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\common\platformbase\Services/ResourceIdentifier.cpp
> When i go to http://localhost/mapguide/mapviewernet/ajaxviewer.aspx i get
> the following error
> An unclassified exception occurred.
> An unclassified exception occurred. Exception occurred in method
> new_MgResourceIdentifier at line 681 in file .\MgApi_wrap.cpp
> What am I missing?
> Thank you
