[mapguide-users] How to embed the map in my own web page?
dorra2007
dorrdor at yahoo.fr
Wed Jan 30 11:30:38 EST 2008
That is what I have done.
And I have always invalid repositorty type.
Kenneth, GEOGRAF A/S wrote:
> You can only display WebLayouts with the viewer.
> You must also enter the full path to the weblayout:
> Library://mylayout.WebLayout
> Regards, Kenneth, GEOGRAF A/S
> dorra2007 skrev:
>> i have an error message: Invalid repository type.
>> Whereas the map is displayed in mapguide studio.
>> NB: I use postgis as data source.
>>> Yes, the mapviewerajax should be configured with the correct default
>>> page.
>>> If you use the "mapviewerjava", you must add ajaxviewer.jsp page name.
>>> The full url becomes:
>>> /mapguide/mapviewerjava/ajaxviewer.jsp?weblayout=Library://mylayout.WebLayout&username=Anonymous&password=
>>> dorra2007 skrev:
>>>> Thank you Kenneth for the code segment;
>>>> But there is no folder named mapviewerajax; so I have changed it to
>>>> mapviewerjava. I have tried it and the result is the title (This is my
>>>> webpage with an embedded map!)+ blank: the map isnot displayed (instead
>>>> of
>>>> the map lays a blank square.)
>>>> Have you an idea about what the problem can be?
>>>>> Yes, it is possible.
>>>>> My favorite method is to embed the Map in an Iframe:
>>>>> <html>
>>>>> <body>
>>>>> <h1>This is my webpage with an embedded map!</h1>
>>>>> <iframe
>>>>> src="/mapguide/mapviewerajax/?weblayout=Library://mylayout.WebLayout&username=Anonymous&password="
>>>>> width="100%" height="100%"></iframe>
>>>>> </body>
>>>>> </html>
>>>>> By adding commands, do you mean from code?
>>>>> What sort of commands do you want to add, and why is Studio not an
>>>>> option?
>>>>> dorra2007 skrev:
>>>>>> Hello all;
>>>>>> I have one precise question: Is it possible to display the mapguide
>>>>>> map
>>>>>> in
>>>>>> my own web page?
>>>>>> If yes; what should I do? And how could I add commands without using
>>>>>> mapguide studio?
>>>>>> Thank you in advance.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/How-to-embed-the-map-in-my-own-web-page--tp15130478s16610p15184538.html
