[mapguide-users] How to embed the map in my own web page?
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Jan 31 13:54:10 EST 2008
This works on my machine, with the Sheboygan data installed:
http://localhost/mapguide/mapviewernet/ajaxviewer.aspx?weblayout=Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout&username=Anonymous&password=
Since you are using Jsp, it should be:
http://localhost/mapguide/mapviewerjava/ajaxviewer.jsp?weblayout=Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout&username=Anonymous&password=
You can paste the url into a browser to test it, before inserting it as
an embedded map.
If you are using the bundled Apache server, you should use:
http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp?weblayout=Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout&username=Anonymous&password=
Regards, Kenneth, GEOGRAF A/S
dorra2007 skrev:
> That is what I have done.
> And I have always invalid repositorty type.
> Kenneth, GEOGRAF A/S wrote:
>> You can only display WebLayouts with the viewer.
>> You must also enter the full path to the weblayout:
>> Library://mylayout.WebLayout
>> dorra2007 skrev:
>>> i have an error message: Invalid repository type.
>>> Whereas the map is displayed in mapguide studio.
>>> NB: I use postgis as data source.
>>>> Yes, the mapviewerajax should be configured with the correct default
>>>> page.
>>>> If you use the "mapviewerjava", you must add ajaxviewer.jsp page name.
>>>> The full url becomes:
>>>> /mapguide/mapviewerjava/ajaxviewer.jsp?weblayout=Library://mylayout.WebLayout&username=Anonymous&password=
>>>> dorra2007 skrev:
>>>>>   Thank you Kenneth for the code segment;
>>>>> But there is no folder named mapviewerajax; so I have changed it to
>>>>> mapviewerjava. I have tried it and the result is the title (This is my
>>>>> webpage with an embedded map!)+ blank: the map isnot displayed (instead
>>>>> of
>>>>> the map lays a blank square.)
>>>>> Have you an idea about what the problem can be?
>>>>>> Yes, it is possible.
>>>>>> My favorite  method is to embed the Map in an Iframe:
>>>>>> <html>
>>>>>> <body>
>>>>>> <h1>This is my webpage with an embedded map!</h1>
>>>>>> <iframe
>>>>>> src="/mapguide/mapviewerajax/?weblayout=Library://mylayout.WebLayout&username=Anonymous&password="
>>>>>> width="100%" height="100%"></iframe>
>>>>>> </body>
>>>>>> </html>
>>>>>> By adding commands, do you mean from code?
>>>>>> What sort of commands do you want to add, and why is Studio not an
>>>>>> option?
>>>>>> dorra2007 skrev:
>>>>>>> Hello all;
>>>>>>> I have one precise question: Is it possible to display the mapguide
>>>>>>> map
>>>>>>> in
>>>>>>> my own web page?
>>>>>>> If yes; what should I do? And how could I add commands without using
>>>>>>> mapguide studio?
>>>>>>> Thank you in advance.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080131/18ca6e20/attachment.html
