[mapguide-users] Problem with PostGIS, FDO and Data Connection
gimbrogno
magnitudo9 at email.it
Thu Jul 3 10:57:15 EDT 2008
I checked the mapguide Error.log, and I found this problem
Error: An exception occurred in FDO component.
The execution of Select command failed.
StackTrace:
- MgFeatureServiceHandler.ProcessOperation line 83 file
FeatureServiceHandler.cpp
- MgOpSelectFeatures.Execute line 109 file OpSelectFeatures.cpp
- MgServerSelectFeatures.SelectFeatures line 249 file
ServerSelectFeatures.cpp An exception occurred in FDO component.
Can anyone direct me to a solution? Thanks in advantage...
View this message in context: http://www.nabble.com/Problem-with-PostGIS%2C-FDO-and-Data-Connection-tp18218250p18260184.html
