[mapguide-users] Expression building with Property extensions... in maestro if possible
Jamo181 adam.jamison at portbris.com.au
Thu Jul 3 18:00:51 EDT 2008
Hi I've done a little searching around and found this to have already been
fixed in this ticket...
http://trac.osgeo.org/mapguide/ticket/282
http://trac.osgeo.org/mapguide/ticket/284
Fixed Describe schema to include the calculated properties from the
extension.
What I was hoping is that someone could tell me the syntax to create a new
calculated property with a some joined data. I'm using Maestro if this
helps....
Current String is
Concat(Concat(Concat(' ,Ext1somesite),' ),Ext1somesitedesc),' ')
Help ?
View this message in context: http://www.nabble.com/Expression-building-with-Property-extensions...-in-maestro-if-possible-tp18269054p18269054.html
