[mapguide-users] Raster images in MGE 2009
Zac Spitzer zac.spitzer at gmail.com
Mon Jul 7 09:55:52 EDT 2008
On Mon, Jul 7, 2008 at 11:23 PM, Dave Brett <dbrett at digitalglobe.com> wrote:
> Zac -
>  i am not sure I exactly understand your suggestion. I looked into the
> FeatureService and the ResourceService and the closest things I can find to
> what you are describing is using the
> ResourceService.GetResourceData/SetResourceData methods.
yep, that's what you need to do
>  can you help me understand your suggestion?
> thanks,
> dave
> zspitzer wrote:
>> try 'touching' the featuresource defintion by opening and saving the
>> xml definition
>> z
>> On Mon, Jul 7, 2008 at 12:17 PM, Dave Brett <dbrett at digitalglobe.com>
>> wrote:
>>> Andy -
>>>  gave that a try and no luck, adding the provider to the
>>> DataConnectionPoolExcludedProviders now causes no imagery to be
>>> displayed.
>>>  do you know if there is any method to force the provider to re-read the
>>> imagery directory and refresh the cache or maybe add a an explict path to
>>> an
>>> image that would be session based?
>>> thanks,
>>> dave
>>> Andy Morsell wrote:
>>>> For your unmanaged raster datasource, it sounds like the connection
>>>> might
>>>> be
>>>> getting cached so the provider is not aware of the new imagery files
>>>> until
>>>> the service is restarted.  You can try adding the providers to the list
>>>> for
>>>> the DataConnectionPoolExcludedProviders parameter in the
>>>> /server/bin/serverconfi.ini file to see if that might solve this
>>>> problem.
>>>> Andy Morsell, P.E.
>>>> Spatial Integrators, Inc.
>>>> www.SpatialGIS.com
>>>> -----Original Message-----
>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Brett
>>>> Sent: Sunday, July 06, 2008 11:53 AM
>>>> To: mapguide-users at lists.osgeo.org
>>>> Subject: [mapguide-users] Raster images in MGE 2009
>>>> I am working on project where the user can navigate to an area of
>>>> interest
>>>> (AOI) within MapGuide and request imagery for that AOI and expect the
>>>> imagery to be displayed.  The AOI selection process is working fine but
>>>> displaying the selected imagery is not working.  The new jpg and
>>>> worldfile
>>>> are downloaded to the specified directory that the provider is aware of
>>>> but
>>>> MapGuide does not display the new imagery.
>>>> What is the trick to get MGE/provider to display the new image file(s)
>>>> as
>>>> the are requested?
>>>> The only success I have had is to restart the MGE server.
>>>> setup:
>>>> MGE2009
>>>> GDAL provider
>>>> Autodesk Raster Provider
>>>> WinXP
>>>> .Net application
>>>> thanks,
>>>> Dave
>>>> View this message in context:
>>>> http://www.nabble.com/Raster-images-in-MGE-2009-tp18304693p18304693.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> http://www.nabble.com/Raster-images-in-MGE-2009-tp18304693p18308990.html
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
> View this message in context: http://www.nabble.com/Raster-images-in-MGE-2009-tp18304693p18316549.html
Zac Spitzer -
+61 405 847 168
