[mapguide-users] Raster images in MGE 2009
Trevor Wekel
trevor.wekel at autodesk.com
Mon Jul 7 13:39:22 EDT 2008
The MGE 2009 raster provider looks at the config.xml document stored with the raster feature source to determine which raster files to load. This document can be accessed using Get/SetResourceData. Autodesk MapGuide Studio regenerates this document when you hit "Test Connection" on the feature source and then save it.
MGE 2009 does not update the config.xml document so any changes to the imagery will not be reflected automatically.
Thanks,
Trevor
-----Original Message-----
From: Zac Spitzer [mailto:zac.spitzer at gmail.com]
Sent: Monday, July 07, 2008 7:56 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Raster images in MGE 2009
On Mon, Jul 7, 2008 at 11:23 PM, Dave Brett <dbrett at digitalglobe.com> wrote:
> Zac -
> i am not sure I exactly understand your suggestion. I looked into the
> FeatureService and the ResourceService and the closest things I can find to
> what you are describing is using the
> ResourceService.GetResourceData/SetResourceData methods.
yep, that's what you need to do
> can you help me understand your suggestion?
> thanks,
> dave
> zspitzer wrote:
>> try 'touching' the featuresource defintion by opening and saving the
>> xml definition
>> z
>> On Mon, Jul 7, 2008 at 12:17 PM, Dave Brett <dbrett at digitalglobe.com>
>> wrote:
>>> Andy -
>>> gave that a try and no luck, adding the provider to the
>>> DataConnectionPoolExcludedProviders now causes no imagery to be
>>> displayed.
>>> do you know if there is any method to force the provider to re-read the
>>> imagery directory and refresh the cache or maybe add a an explict path to
>>> an
>>> image that would be session based?
>>> thanks,
>>> dave
>>> Andy Morsell wrote:
>>>> For your unmanaged raster datasource, it sounds like the connection
>>>> might
>>>> be
>>>> getting cached so the provider is not aware of the new imagery files
>>>> until
>>>> the service is restarted. You can try adding the providers to the list
>>>> for
>>>> the DataConnectionPoolExcludedProviders parameter in the
>>>> /server/bin/serverconfi.ini file to see if that might solve this
>>>> problem.
>>>> Andy Morsell, P.E.
>>>> Spatial Integrators, Inc.
>>>> www.SpatialGIS.com
>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Brett
>>>> Sent: Sunday, July 06, 2008 11:53 AM
>>>> To: mapguide-users at lists.osgeo.org
>>>> Subject: [mapguide-users] Raster images in MGE 2009
>>>> I am working on project where the user can navigate to an area of
>>>> interest
>>>> (AOI) within MapGuide and request imagery for that AOI and expect the
>>>> imagery to be displayed. The AOI selection process is working fine but
>>>> displaying the selected imagery is not working. The new jpg and
>>>> worldfile
>>>> are downloaded to the specified directory that the provider is aware of
>>>> but
>>>> MapGuide does not display the new imagery.
>>>> What is the trick to get MGE/provider to display the new image file(s)
>>>> as
>>>> the are requested?
>>>> The only success I have had is to restart the MGE server.
>>>> setup:
>>>> MGE2009
>>>> GDAL provider
>>>> Autodesk Raster Provider
>>>> WinXP
>>>> .Net application
>>>> thanks,
>>>> Dave
>>>> View this message in context:
>>>> http://www.nabble.com/Raster-images-in-MGE-2009-tp18304693p18304693.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> http://www.nabble.com/Raster-images-in-MGE-2009-tp18304693p18308990.html
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
> View this message in context: http://www.nabble.com/Raster-images-in-MGE-2009-tp18304693p18316549.html
Zac Spitzer -
+61 405 847 168
