[mapguide-users] Adding a new feature class to an already
existing feature schema
Brent Robinson
brent.robinson at autodesk.com
Tue Jul 15 12:23:47 EDT 2008
Hi Carl,
I don't believe the Feature Service supports modifying feature schemas so you'd have to use the FDO API. The steps for the managed API would be something like:
IConnection conn;
// ... create and open connection to provider
IDescribeSchema descSchema = conn.CreateCommand(CommandType.CommandType_DescribeSchema) as IDescribeSchema;
FeatureSchemaCollection schemas = descSchema.Execute();
FeatureSchema schema = schemas["myschema"];
FeatureClass featClass = new FeatureClass("newClass", "description");
// ... add properties to the new class.
ClassCollection classes = schema.Classes;
classes.Add(featClass);
IApplySchema applySchema = conn.CreateCommand(CommandType.CommandType_ApplySchema) as IApplySchema;
applySchema.FeatureSchema = schema;
applySchema.Execute();
You can also create a new feature schema by instantiating a new FeatureSchema object, optionally populating it with classes and passing it to an IApplySchema command.
Note that not all providers support multiple feature schemas (SDF is limited to just one per file).
Brent.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Carl Jokl
Sent: Tuesday, July 15, 2008 9:01 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Adding a new feature class to an already existing feature schema
I wondered if anyone knows how to programatically add a new feature class
definition to an existing feature schema. All the example code I have goes
on the basis of creating the new class and the schema together in one step
but I don't have any examples of how to go about retrospectively adding a
new class to an existing feature schema.
I have so far got to the point of getting hold of an instance of the feature
service and using the DescribeSchema method to retrieve the schema I wish to
add to. I can get hold of the schema's class collection and add the new
class to this but I am not sure if that will persist the new feature class
or if I have to somehow persist the changes to the schema after adding the
new class to it.
Has anyone done this / know how it needs to be done?
View this message in context: http://www.nabble.com/Adding-a-new-feature-class-to-an-already-existing-feature-schema-tp18464689p18464689.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
