[mapguide-users] Using .NET Api to connect from a different Machine
Johann Nothbauer
nothbauer at rmdata.at
Thu Jul 17 08:04:21 EDT 2008
Hi all!
I'm trying to use the .NET Api to establish a connection to a Mapguide
2.0.1 Site without using a Web Viewer. My Application is a smart client
and should run on a different Machine the MapGuide Server runs on.
So I tried the following (in a Winforms Button_Click):
MapGuideApi.MgInitializeWebTier("webconfig.ini");
// Connect to the site.
MgUserInformation userInfo = new MgUserInformation("Administrator",
"admin");
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
MgResourceService resService =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
This works so far, but when I try to use the Resource-Service like this:
MgResourceIdentifier resID = new MgResourceIdentifier("Library://");
MgByteReader resEnum = resService.EnumerateResources(resID, -1, "");
the API throws get an "OSGeo.MapGuide.MgConnectionFailedException"
(Message: "Cannot establish connection").
The same code works on the MapGuide Server Machine.
Is it possible to use the API to connect to a Mapguide Server on a
different machine? Or do I have to use the Web-API (XML) over HTTP? I
can change all my firewall rules, no problem.
Any Ideas?
Thanx,
Nothi
