[mapguide-users] Using .NET Api to connect from a different Machine
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jul 17 09:21:52 EDT 2008
The file "webconfig.ini" must be changed to point to the correct server
instead of "127.0.0.1".
Its under the section [SiteConnectionProperties]
IpAddress                          =127.0.0.1
Port                               = 2812
You might also have to copy some of the folders referenced in there,
depending on what you want to do.
I would not recommend doing this over the internet, because the data
transmitted over the wire ends up in the MapGuide server process which
runs in the "Local System Account".
Regards, Kenneth Skovhede, GEOGRAF A/S
Johann Nothbauer skrev:
> Hi all!
> I'm trying to use the .NET Api to establish a connection to a Mapguide
> 2.0.1 Site without using a Web Viewer. My Application is a smart
> client and should run on a different Machine the MapGuide Server runs on.
> So I tried the following (in a Winforms Button_Click):
> MapGuideApi.MgInitializeWebTier("webconfig.ini");
> // Connect to the site.
> MgUserInformation userInfo = new MgUserInformation("Administrator",
> "admin");
> MgSiteConnection siteConnection = new MgSiteConnection();
> siteConnection.Open(userInfo);
> MgResourceService resService =
> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
> This works so far, but when I try to use the Resource-Service like this:
> MgResourceIdentifier resID = new MgResourceIdentifier("Library://");
> MgByteReader resEnum = resService.EnumerateResources(resID, -1, "");
> the API throws get an "OSGeo.MapGuide.MgConnectionFailedException"
> (Message: "Cannot establish connection").
> The same code works on the MapGuide Server Machine.
> Is it possible to use the API to connect to a Mapguide Server on a
> different machine? Or do I have to use the Web-API (XML) over HTTP? I
> can change all my firewall rules, no problem.
> Any Ideas?
> Thanx,
> Nothi
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
