[mapguide-users] MAESTRO and FDO
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Jul 18 05:07:05 EDT 2008
What version of Maestro are you using (Click Help -> About)?
I have just tried reproducing in 1.0.8.27399 and I have no problems
creating line styles.
You should be able to click the green plus sign, and then alter the line
display style.
Regards, Kenneth Skovhede, GEOGRAF A/S
Edmondo skrev:
> Edmondo wrote:
>> Dear All,
>> I have a .shp with parcels. I connected this file in MPG MAESTRO by FDO
>> (unmanaged file... test connection works fine)
>> and added the source to a layer, added the layer to a new map, made new
>> layout.
>> My browser doesn't show the map.
>> Trying to add feature to display (area for example) MAESTRO returns an
>> error,
>> But it seems the shape is correct: I opened the file in ARCGIS and it
>> contains areas and other metadata.
>> I seen Seboyang data examples (there are only .sdf format) and the
>> GEOMETRY field contains "SHPGEOMETRY" instead in with my shape
>> the same field contains "GEOMETRY"
>> Someone can explain me the correct way to add a shape?
>> Sorry for my questions (and for my english), but I started with WEBGIS
>> just few days ago.
>> Thanks
>> E.
> http://www.nabble.com/file/p18525187/error.jpg
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080718/bbb5d4f4/attachment.html
