[mapguide-users] Selection Issue (FeatureReader only grabbing
20 items)
nclayton
nclayton at gmail.com
Mon Jul 21 11:53:27 EDT 2008
I altered the value for SelectionFilterSize and set it to 9999 then restarted
the MapGuide service.
I'm still only getting the first 20.
Don C. MacGregor wrote:
> Earlier it was suggested by Jonathon...
> Check out the serverconfig.ini file...there is a new setting in there that
> limits it.
> nclayton wrote:
>> Hi all,
>> This has just recently become a problem. I am passing the selection xml
>> to a page to display parcel owner data. For an example, I select 256
>> parcels on the map. The selection xml comes over fine, with all 256
>> parcels listed. When I use a featureReader to get the parcel numbers from
>> the features, It only get the first 20.
>> Is this a setting I may have altered unintentionally, or could there be
>> more to it?
>> Here is the code that I am using to pull the information out from the
>> selection xml:
>> function GetObjKeys($sessId,$mapName,$sel){
>> $obj_keys = '';
>> if($sel != ''){
>> InitializeWebTier();
>> $userInfo = new MgUserInformation($sessId);
>> $siteConnection = new MgSiteConnection();
>> $siteConnection->Open($userInfo);
>> $resourceService =
>> $siteConnection->CreateService(MgServiceType::ResourceService);
>> $featureService =
>> $siteConnection->CreateService(MgServiceType::FeatureService);
>> $map = new MgMap($siteConnection);
>> $map->Open($resourceService,$mapName);
>> $selection = new MgSelection($map,$sel);
>> if($selection != ''){
>> $layers = $selection->GetLayers();
>> if(!$layers){ $layers = $map->GetLayers(); }
>> }else{ $layers = 0; }
>> $layer = null;
>> if($layers){
>> for($i = 0; $i < $layers->GetCount(); $i++){
>> if($layers->GetItem($i)->GetName() == "parcels"){ $layer =
>> $layers->GetItem($i); }
>> $queryOptions = new MgFeatureQueryOptions();
>> if($layer){
>> $layerClassName = $layer->GetFeatureClassName();
>> if($sel != ''){ $selString =
>> $selection->GenerateFilter($layer,$layerClassName); }
>> $layerFeatureId = $layer->GetFeatureSourceId();
>> $layerFeatureResource = new
>> MgResourceIdentifier($layerFeatureId);
>> $layerId = $layer->GetObjectId();
>> $queryOptions->SetFilter($selString);
>> $featureReader =
>> $featureService->SelectFeatures($layerFeatureResource,$layerClassName,$queryOptions);
>> $selTmp = '';
>> for($pdx=0; $pdx<$featureReader->GetPropertyCount(); $pdx++){
>> $pnm = $featureReader->GetPropertyName($pdx);
>> if($pnm == 'PARCEL_ID_'){ break; }
>> if($pnm == 'PARCELID'){ break; }
>> if($pnm == 'Key'){ break; }
>> $pnm = "";
>> if($pnm != ""){
>> while($featureReader->ReadNext()){
>> $stg = $featureReader->GetString($pnm);
>> if($stg != ""){ $obj_keys .= "'" . $stg . "'"; }
>> $obj_keys = str_replace("''","','",$obj_keys);
>> return $obj_keys;
>> }else{ return ''; }
View this message in context: http://www.nabble.com/Selection-Issue-%28FeatureReader-only-grabbing-20-items%29-tp18570994p18571636.html
