[mapguide-users] Selection Issue (FeatureReader only grabbing
20 items)
Don C. MacGregor
sir_sunkee at yahoo.ca
Mon Jul 21 12:59:10 EDT 2008
You also need to modify the SelectionFilterSize value in webconfig.ini file.
nclayton wrote:
> I altered the value for SelectionFilterSize and set it to 9999 then
> restarted the MapGuide service.
> I'm still only getting the first 20.
> Don C. MacGregor wrote:
>> Earlier it was suggested by Jonathon...
>> Check out the serverconfig.ini file...there is a new setting in there
>> that limits it.
>> nclayton wrote:
>>> Hi all,
>>> This has just recently become a problem. I am passing the selection xml
>>> to a page to display parcel owner data. For an example, I select 256
>>> parcels on the map. The selection xml comes over fine, with all 256
>>> parcels listed. When I use a featureReader to get the parcel numbers
>>> from the features, It only get the first 20.
>>> Is this a setting I may have altered unintentionally, or could there be
>>> more to it?
>>> Here is the code that I am using to pull the information out from the
>>> selection xml:
>>> function GetObjKeys($sessId,$mapName,$sel){
>>> $obj_keys = '';
>>> if($sel != ''){
>>> InitializeWebTier();
>>> $userInfo = new MgUserInformation($sessId);
>>> $siteConnection = new MgSiteConnection();
>>> $siteConnection->Open($userInfo);
>>> $resourceService =
>>> $siteConnection->CreateService(MgServiceType::ResourceService);
>>> $featureService =
>>> $siteConnection->CreateService(MgServiceType::FeatureService);
>>> $map = new MgMap($siteConnection);
>>> $map->Open($resourceService,$mapName);
>>> $selection = new MgSelection($map,$sel);
>>> if($selection != ''){
>>> $layers = $selection->GetLayers();
>>> if(!$layers){ $layers = $map->GetLayers(); }
>>> }else{ $layers = 0; }
>>> $layer = null;
>>> if($layers){
>>> for($i = 0; $i < $layers->GetCount(); $i++){
>>> if($layers->GetItem($i)->GetName() == "parcels"){ $layer =
>>> $layers->GetItem($i); }
>>> $queryOptions = new MgFeatureQueryOptions();
>>> if($layer){
>>> $layerClassName = $layer->GetFeatureClassName();
>>> if($sel != ''){ $selString =
>>> $selection->GenerateFilter($layer,$layerClassName); }
>>> $layerFeatureId = $layer->GetFeatureSourceId();
>>> $layerFeatureResource = new
>>> MgResourceIdentifier($layerFeatureId);
>>> $layerId = $layer->GetObjectId();
>>> $queryOptions->SetFilter($selString);
>>> $featureReader =
>>> $featureService->SelectFeatures($layerFeatureResource,$layerClassName,$queryOptions);
>>> $selTmp = '';
>>> for($pdx=0; $pdx<$featureReader->GetPropertyCount(); $pdx++){
>>> $pnm = $featureReader->GetPropertyName($pdx);
>>> if($pnm == 'PARCEL_ID_'){ break; }
>>> if($pnm == 'PARCELID'){ break; }
>>> if($pnm == 'Key'){ break; }
>>> $pnm = "";
>>> if($pnm != ""){
>>> while($featureReader->ReadNext()){
>>> $stg = $featureReader->GetString($pnm);
>>> if($stg != ""){ $obj_keys .= "'" . $stg . "'"; }
>>> $obj_keys = str_replace("''","','",$obj_keys);
>>> return $obj_keys;
>>> }else{ return ''; }
View this message in context: http://www.nabble.com/Selection-Issue-%28FeatureReader-only-grabbing-20-items%29-tp18570994p18572979.html
