[mapguide-users] Is it possible to create join on join ?
Haris Kurtagic
haris at sl-king.com
Fri Jul 25 02:31:24 EDT 2008
You need to set KingFdoClass table name in connection properties.
The field you are looking in dialog is only to display currently used
Table Name as Kingfdoclass table.
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Krunoslav
Sent: Friday, July 25, 2008 8:11 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Is it possible to create join on join ?
Kenneth Skovhede, GEOGRAF A/S wrote:
> Your table must have a primary key, otherwise selection will not work
as
> expected.
> If you are using views, you must create a special table to declare
this.
> Instructions are here:
> http://www.sl-king.com/fdooracle/KingFdoClass.htm
Thank you and Haris.
I have just one small problem now: I use FDO2FDO tool, and when I go to
Oracle Toolbox -> KingFDOClass and pressing any button, I get error
"KingFdoClass connection property is empty! Set Table name to be used in
connection property 'KingFdoClass'".
But, the field KingFdoClass Table Name is disabled and I can't enter
anything in it.
Any ideas?
View this message in context:
http://www.nabble.com/Is-it-possible-to-create-join-on-join---tp18608710
p18645808.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
