[mapguide-users] Fusion map insists on refreshing
map on selection, and clear selection...
Mike Adair
madair at dmsolutions.ca
Fri Jul 25 15:44:28 EDT 2008
Yes a nightly or weekly build would be helpful but the build script for
creating the distribution doesn't do much more than zip up all the files
(it does generate documentation and compress some of the javascript).
You can check out the trunk directory tree from SVN and get essentially
the same thing that would be in the zip file.
Now we also have the singleFile build target in trunk which will create
a compressed JS file based on the contents of the ApplicationDefinition
file. This is probably the preferred way of compressing now and it
produces a different JS file with only the files required for each
application. see http://trac.osgeo.org/fusion/wiki/ANTBuildSystem
Mike
Andrew DeMerchant wrote:
> I have no clue about how to make my own fusion build - which is why
> I've been checking the GetIt page. It's something I've mentioned on
> this mailing list before, but it'd be great if we could get access to
> more cutting edge builds of things, like the Mozilla folks do. Right
> now, the only project related to Mapguide that's doing that is
> Maestro, which has already helped a lot to get bugs worked out.
> Nightly, weekly, or even monthly builds would be great!
> Andrew
> Jason Fournier wrote:
>> Hi Andrew,
>> I believe Paul would like 1.1 released for end of Summer.
>> Have you tried checking out trunk from svn.osgeo.org/fusion and
>> seeing if that addresses your issues? I wouldn’t suggest using trunk
>> for production purposes -- but at least it would give you an idea if
>> OL 2.6 works better for your needs. If it does not we may be able to
>> use the feedback to make further enhancements in time for 1.1.
>> I don’t think a 1.0.7 release would have OL 2.6 (correct me if I’m
>> wrong Mike).
>> Thanks,
>> Jason
>> *From:* mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
>> DeMerchant
>> *Sent:* Friday, July 25, 2008 1:19 PM
>> *To:* MapGuide Users Mail List
>> *Subject:* Re: [mapguide-users] Fusion map insists on refreshing map
>> Is there some way for someone to put 1.0 (or anything newer than
>> 1.0.6) on the GetIt site? Otherwise, I'm going to have to go live
>> with a project using AJAX and then maybe switch over to Fusion just
>> after my users get used to AJAX. It'd be really great to start off in
>> Fusion. It looks so much nicer...
>> Andrew
>> Mike Adair wrote:
>> Paul or Jason may want to weigh in on this when he gets back from
>> vacation but I believe we were targeting for the end of summer to have
>> 1.1 ready.
>> Mike
>> Is there any update to this yet? When's v1.1 going to be available (or
>> any version with the fix)? This problem with refreshing maps is a
>> blocker for me - I can't use Fusion on my projects with this
>> bug...it's just too slow compared to AJAX. I keep checking
>> http://trac.osgeo.org/fusion/wiki/GetIt in hopes to find something
>> new, but it never seems to get updated.
>> Andrew
>> Missed that one....sorry. When is v1.1 going to be available?
>> Andrew
>> Berdel, Brian wrote:
>> Here is a recent post on this.
>> v1.1 of Fusion will incorporate v2.6 of OpenLayers which should
>> eliminate this problem and also gives us smooth transition effects
>> for zoom and panning. This has already been added to the trunk
>> version of fusion.
>> Mike
>> -----Original Message-----
>> From: foolfish <xjimmyshcn at sohu.com> <mailto:xjimmyshcn at sohu.com>
>> Sent: Wednesday, June 4, 2008 11:53pm
>> To: mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>> Subject: [mapguide-users] map flicker when refresh!!!
>> when i use traditional method(not use fusion),when i show or hide a
>> layer,it
>> won't flickering。
>> but,in fusion,i use Legend Panel (Layer Manager) to show or hide a
>> layer,but
>> the map is flickering obviously,it‘s not well〜
>> does anybody know how to solve the problem? wait for your help,thanks~
>> View this message in context:
>> http://www.nabble.com/map-flicker-when-refresh%21%21%21-tp17661479p17661479.html
>> Brian
>> *From:* mapguide-users-bounces at lists.osgeo.org <mailto:mapguide-users-bounces at lists.osgeo.org>
>> *Andrew DeMerchant
>> *Sent:* Monday, June 09, 2008 3:29 PM
>> *Subject:* [mapguide-users] Fusion map insists on refreshing map on
>> selection,and clear selection...
>> Just wondering if there's a way to stop fusion maps from redrawing
>> the map everytime a user selects / deselects something? This doesn't
>> happen using the AJAX browser...does this happen for anyone else?
>> Andrew
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> *Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
>> *Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
>> *Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
