[mapguide-users] MG 1.2 vs 2.0.1
Zac Spitzer zac.spitzer at gmail.com
Thu Jul 31 12:18:56 EDT 2008
Are you checking the result as bellow
result=featureService.UpdateFeatures(resourceID, fCommand, false);
if (result.GetItem(0).GetPropertyType() eq 9)
    result.GetItem(0).GetValue() // Silent FDO error messages!!!!
z
On Fri, Aug 1, 2008 at 2:14 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> can you post some code to demonstrate the problem?
> On Fri, Aug 1, 2008 at 2:05 AM, George McLean <gmclean at gorge.net> wrote:
>> Hello,
>> I am a bit stuck in upgrading to 2.0.1 mainly due to the issues with adding
>> data to feature sources discussed in this thread:
>> http://www.nabble.com/Please-try-your-operation-later-as-the-resource-was-busy-to16392736.html#a18556960
>> My immediate issue is that I have a client that would really like to us FF
>> 3.0 with my application. I see that either I need to find a way to apply the
>> fixes made in 2.0 for FF to 1.2 or find a way around the issues with
>> updating feature data.
>> I could look at the code for MG 1.2 and apply the changes made to 2.0 with
>> some guidance on where to start but I think I would rather find a fix for MG
>> 2.0.
>> Any suggestions would be appreciated.
>> Thanks
>> George McLean
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
