[mapguide-users] MG 1.2 vs 2.0.1
George McLean gmclean at gorge.net
Thu Jul 31 14:16:17 EDT 2008
No I am not. Does this ignore the error message and process the update
somehow?
Zac Spitzer wrote:
> Are you checking the result as bellow
> result=featureService.UpdateFeatures(resourceID, fCommand, false);
> if (result.GetItem(0).GetPropertyType() eq 9)
>     result.GetItem(0).GetValue() // Silent FDO error messages!!!!
> z
> On Fri, Aug 1, 2008 at 2:14 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> can you post some code to demonstrate the problem?
>> On Fri, Aug 1, 2008 at 2:05 AM, George McLean <gmclean at gorge.net> wrote:
>>> Hello,
>>> I am a bit stuck in upgrading to 2.0.1 mainly due to the issues with adding
>>> data to feature sources discussed in this thread:
>>> http://www.nabble.com/Please-try-your-operation-later-as-the-resource-was-busy-to16392736.html#a18556960
>>> My immediate issue is that I have a client that would really like to us FF
>>> 3.0 with my application. I see that either I need to find a way to apply the
>>> fixes made in 2.0 for FF to 1.2 or find a way around the issues with
>>> updating feature data.
>>> I could look at the code for MG 1.2 and apply the changes made to 2.0 with
>>> some guidance on where to start but I think I would rather find a fix for MG
>>> 2.0.
>>> Any suggestions would be appreciated.
>>> Thanks
>>> George McLean
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
