[ZS1] [mapguide-users] Shareable markups
erictsn at cadbeyond.com erictsn at cadbeyond.com
Sun Jun 1 11:18:08 EDT 2008
I found the error of the error_log from apache as following:
[Sun Jun 01 19:15:10 2008] [error] [client 221.126.8.61] PHP Warning:
Missing argument 7 for BuildClientSideTree(), called in
/opt/Autodesk/mapguideenterprise2009/webserverextensions/www/mapviewerphp/legend.php
on line 89 and defined in /opt/Autodesk/mapguideenterprise2009/$
[Sun Jun 01 19:15:13 2008] [error] [client 221.126.8.61] PHP Warning:
[Sun Jun 01 19:15:21 2008] [error] [client 221.126.8.61] PHP Fatal error:
Cannot create swig object type: MgCoordinateSystemTransform as the
underlying object is abstract in
/opt/Autodesk/mapguideenterprise2009/webserverextensions/www/phpgenerictasks/markup/classes/markuped$
[Sun Jun 01 19:15:33 2008] [error] [client 221.126.8.61] PHP Fatal error:
[Sun Jun 01 19:15:44 2008] [error] [client 221.126.8.61] PHP Fatal error:
Eric
On Sat, 31 May 2008 19:42:40 -0700, "Jason Birch" <Jason.Birch at nanaimo.ca>
wrote:
> All I can see is a 500-series server error.  I wonder if you'd get
anything
> different if you turned on display_errors in your php.ini file (and
> restarted Apache)?
> If not, I think you'd have to trace your way through that file with print
> / exit pairs until it started breaking so you could see what was going
> wrong.
> Also, I don't know that script; if it's not using try/catch blocks,
> MapGuide errors won't show up properly.
> Jason
> ________________________________
> From: erictsn <mailto:erictsn at cadbeyond.com>
> Subject: Re: [ZS1] [mapguide-users] Shareable markups
> Thanks for your reply.
> At this moments, I do not have idea why it can't to work! I created the
> user called "Markup" and the repository (Markup) has been created
> automatically. http://59.188.30.133:81/mapguide2009/phpgenerictasks/ This
> is the testing server. I have attached the phpgenerictasks files. Anybody
> have idea? Thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
