[ZS1] [mapguide-users] Shareable markups
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sun Jun 1 11:33:48 EDT 2008
That is a known issue. I guess the GT sample is not up to date:
http://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg03513.html
Regards, Kenneth Skovhede, GEOGRAF A/S
erictsn at cadbeyond.com skrev:
> I found the error of the error_log from apache as following:
> [Sun Jun 01 19:15:10 2008] [error] [client 221.126.8.61] PHP Warning:
> Missing argument 7 for BuildClientSideTree(), called in
> /opt/Autodesk/mapguideenterprise2009/webserverextensions/www/mapviewerphp/legend.php
> on line 89 and defined in /opt/Autodesk/mapguideenterprise2009/$
> [Sun Jun 01 19:15:13 2008] [error] [client 221.126.8.61] PHP Warning:
> [Sun Jun 01 19:15:21 2008] [error] [client 221.126.8.61] PHP Fatal error:
> Cannot create swig object type: MgCoordinateSystemTransform as the
> underlying object is abstract in
> /opt/Autodesk/mapguideenterprise2009/webserverextensions/www/phpgenerictasks/markup/classes/markuped$
> [Sun Jun 01 19:15:33 2008] [error] [client 221.126.8.61] PHP Fatal error:
> [Sun Jun 01 19:15:44 2008] [error] [client 221.126.8.61] PHP Fatal error:
> Eric
> On Sat, 31 May 2008 19:42:40 -0700, "Jason Birch" <Jason.Birch at nanaimo.ca>
> wrote:
>> All I can see is a 500-series server error.  I wonder if you'd get
> anything
>> different if you turned on display_errors in your php.ini file (and
>> restarted Apache)?
>> If not, I think you'd have to trace your way through that file with print
>> / exit pairs until it started breaking so you could see what was going
>> wrong.
>> Also, I don't know that script; if it's not using try/catch blocks,
>> MapGuide errors won't show up properly.
>> Jason
>> ________________________________
>> From: erictsn <mailto:erictsn at cadbeyond.com>
>> Subject: Re: [ZS1] [mapguide-users] Shareable markups
>> Thanks for your reply.
>> At this moments, I do not have idea why it can't to work! I created the
>> user called "Markup" and the repository (Markup) has been created
>> automatically. http://59.188.30.133:81/mapguide2009/phpgenerictasks/ This
>> is the testing server. I have attached the phpgenerictasks files. Anybody
>> have idea? Thanks
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080601/ddcf3d63/attachment.html
