[mapguide-users] [ZS1] Shareable markups
Mauricio Villablanca mgvillablanca at yahoo.com
Sun Jun 1 14:51:29 EDT 2008
In order to get the shareable Markkups working first you need to update the
path to your webconfig.ini file (you do that in your common.php file in that
line with the $webConFigPath variable). Then modify the script so that the
markups will show up in your map. Also if you want to save your markups ina
different folder, you need to change all references pointing to the
'Library:\\Masrkups\' folder.
That's pretty much it.
View this message in context: http://www.nabble.com/Shareable-markups-tp17542284p17588771.html
