[mapguide-users] [ZS1] Shareable markups
erictsn at cadbeyond.com
Sun Jun 1 22:04:02 EDT 2008
Thanks for your reply Mauricio.
I copied the common.php of mapviewerphp folder:
I can't to find the $webConFigPath variable of common.php. Actually I did
follow the instruction to isntall MGE. So the path should be by default
setting. The platform is CentOS 4.6 and installed MapGuide 2009. Does it
the "/" or "\" error? Thanks in advance.
<?php
// Copyright (C) 2004-2008 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
// modify it under the terms of version 2.1 of the GNU Lesser
// General Public License as published by the Free Software Foundation.
// This library is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
// Lesser General Public License for more details.
// You should have received a copy of the GNU Lesser General Public
// License along with this library; if not, write to the Free Software
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301
USA
function InitializeWebTier()
// Initialize web tier with the site configuration file. The config
// file should be two directory levels above this script.
$thisFile = __FILE__;
$pos = strrpos($thisFile, '\\');
if ($pos == false)
$pos = strrpos($thisFile, '/');
$cfgFile = substr($thisFile, 0, $pos+1) . "../webconfig.ini";
MgInitializeWebTier($cfgFile);
function GetDefaultLocale()
return "en"; // localizable string
function GetLocalizationPath()
if ($pos == false)
return substr($thisFile, 0, $pos+1) . "../localized/";
function FormatMessage($id, $locale, $params)
$text = GetString($id, $locale);
for($i = 0; $i < count($params); $i++)
$tag = "{" . $i . "}";
$pos1 = strpos($text, $tag);
if($pos1 == false)
break;
if($pos1 > 0)
$begin = substr($text, 0, $pos1);
else
$begin = "";
$end = substr($text, $pos1 + strlen($tag));
$text = $begin . $params[$i] . $end;
return $text;
function GetSurroundVirtualPath()
if (isset($_SERVER["REQUEST_URI"]))
$path = $_SERVER["REQUEST_URI"];
$baseuri = substr($path, 0, strrpos($path, '?') + 1);
else
$baseuri = $_SERVER["PHP_SELF"];
return substr($baseuri, 0, strrpos($baseuri, '/') + 1);
function GetRootVirtualFolder()
else
return substr($baseuri, 0, strpos($baseuri, '/', 1));
function GetClientOS() {
if(!isset($_SERVER['HTTP_USER_AGENT']))
return 0;
$agent = $_SERVER['HTTP_USER_AGENT'];
if(strpos($agent, "Windows") != FALSE)
return 0;
else if(strpos($agent, "Macintosh") != FALSE)
return 1;
return 2;
function EscapeForHtml($str)
$org = array("'", "\"", "\n", "<", ">");
$repl = array("'", """, " ", "<", ">" );
return str_replace($org, $repl, $str);
function GetDecimalFromLocalizedString($numberString, $locale)
if($locale != null && $numberString != null)
// Remove thousand separators
$thousandSeparator = GetLocalizedString("THOUSANDSEPARATOR",
$locale);
if($thousandSeparator != null && strlen($thousandSeparator) > 0)
$numberString = str_replace($thousandSeparator, "",
$numberString);
// Replace localized decimal separators with "."
$decimalSeparator = GetLocalizedString("DECIMALSEPARATOR",
$locale);
if($decimalSeparator != null && strlen($decimalSeparator) > 0 &&
$decimalSeparator != ".")
$numberString = str_replace($decimalSeparator, ".",
$numberString);
return $numberString;
On Sun, 1 Jun 2008 11:51:29 -0700 (PDT), Mauricio Villablanca
<mgvillablanca at yahoo.com> wrote:
> In order to get the shareable Markkups working first you need to update
> the
> path to your webconfig.ini file (you do that in your common.php file in
> that
> line with the $webConFigPath variable). Then modify the script so that
the
> markups will show up in your map. Also if you want to save your markups
> ina
> different folder, you need to change all references pointing to the
> 'Library:\\Masrkups\' folder.
> That's pretty much it.
> http://www.nabble.com/Shareable-markups-tp17542284p17588771.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
