[ZS1] [mapguide-users] Shareable markups
Rahul unicorn_admirer at yahoo.com
Sun Jun 1 23:32:02 EDT 2008
Hi ,
        I think i send u the code and what to change as u can clearly see that this issue is related with the RFC 35change ,please refer to my previous e-mail and the code so atleast u can get going with the GT Sample-Query and Themes in the MGOS 2.1.0,as of now i haven't checked abt shareable markups.
Regariding the Missing argument 7 for BuildClientSideTree(), may be you have to check the legend.php file as it use to have  BuildClientSideTree($tree, null, "null", false, "layerData", null); with6 parameters instead of BuildClientSideTree($tree, null, "null", false, "layerData",$resourceSrvc, null); with 7 Parameters.I hope this will help you out !!
Max
----- Original Message ----
From: "Kenneth Skovhede, GEOGRAF A/S" <ks at geograf.dk>
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Sunday, June 1, 2008 10:33:48 PM
Subject: Re: [ZS1] [mapguide-users] Shareable markups
That is a known issue. I guess the GT sample is not up to date:
http://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg03513.html
Regards, Kenneth Skovhede, GEOGRAF A/S
erictsn at cadbeyond.com skrev:
I found the error of the error_log from apache as following:
[Sun Jun 01 19:15:10 2008] [error] [client 221.126.8.61] PHP Warning:
Missing argument 7 for BuildClientSideTree(), called in
/opt/Autodesk/mapguideenterprise2009/webserverextensions/www/mapviewerphp/legend.php
on line 89 and defined in /opt/Autodesk/mapguideenterprise2009/$
[Sun Jun 01 19:15:13 2008] [error] [client 221.126.8.61] PHP Warning:
[Sun Jun 01 19:15:21 2008] [error] [client 221.126.8.61] PHP Fatal error:
Cannot create swig object type: MgCoordinateSystemTransform as the
underlying object is abstract in
/opt/Autodesk/mapguideenterprise2009/webserverextensions/www/phpgenerictasks/markup/classes/markuped$
[Sun Jun 01 19:15:33 2008] [error] [client 221.126.8.61] PHP Fatal error:
[Sun Jun 01 19:15:44 2008] [error] [client 221.126.8.61] PHP Fatal error:
Eric
On Sat, 31 May 2008 19:42:40 -0700, "Jason Birch" <Jason.Birch at nanaimo.ca>
wrote:
All I can see is a 500-series server error.  I wonder if you'd get
anything
different if you turned on display_errors in your php.ini file (and
restarted Apache)?
If not, I think you'd have to trace your way through that file with print
/ exit pairs until it started breaking so you could see what was going
wrong.
Also, I don't know that script; if it's not using try/catch blocks,
MapGuide errors won't show up properly.
Jason
Thanks for your reply.
At this moments, I do not have idea why it can't to work! I created the
user called "Markup" and the repository (Markup) has been created
automatically. http://59.188.30.133:81/mapguide2009/phpgenerictasks/ This
is the testing server. I have attached the phpgenerictasks files. Anybody
have idea? Thanks
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080601/0b6381b9/attachment.html
