[mapguide-users] [ZS1] Shareable markups
Rahul unicorn_admirer at yahoo.com
Sun Jun 1 23:54:07 EDT 2008
        I think Try to change function GetTransform() in the markupeditor.php file , Give a Try !!
  $coordSysFactory = new MgCoordinateSystemFactory();
  $resourceService = $this->site->CreateService(MgServiceType::ResourceService);
  $map = new MgMap();
  $map->Open($resourceService, $this->args['MAPNAME']);
  $source = $coordSysFactory->Create($map->GetMapSRS());
  $target = $coordSysFactory->Create(MarkupManager::LL84WKT);
  // return new MgCoordinateSystemTransform($source, $target);
  return $coordSysFactory->GetTransform($source, $target);
THIS SHOULD BE CHANGED for the RFC35
Cheers
Max !!
----- Original Message ----
From: "erictsn at cadbeyond.com" <erictsn at cadbeyond.com>
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Monday, June 2, 2008 9:04:02 AM
Subject: Re: [mapguide-users] [ZS1] Shareable markups
Thanks for your reply Mauricio.
I copied the common.php of mapviewerphp folder:
I can't to find the $webConFigPath variable of common.php. Actually I did
follow the instruction to isntall MGE. So the path should be by default
setting. The platform is CentOS 4.6 and installed MapGuide 2009. Does it
the "/" or "\" error? Thanks in advance.
<?php
//  Copyright (C) 2004-2008 by Autodesk, Inc.
//  This library is free software; you can redistribute it and/or
//  modify it under the terms of version 2.1 of the GNU Lesser
//  General Public License as published by the Free Software Foundation.
//  This library is distributed in the hope that it will be useful,
//  but WITHOUT ANY WARRANTY; without even the implied warranty of
//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
//  Lesser General Public License for more details.
//  You should have received a copy of the GNU Lesser General Public
//  License along with this library; if not, write to the Free Software
//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301
USA
function InitializeWebTier()
    // Initialize web tier with the site configuration file.  The config
    // file should be two directory levels above this script.
    $thisFile = __FILE__;
    $pos = strrpos($thisFile, '\\');
    if ($pos == false)
        $pos = strrpos($thisFile, '/');
    $cfgFile = substr($thisFile, 0, $pos+1) . "../webconfig.ini";
    MgInitializeWebTier($cfgFile);
function GetDefaultLocale()
    return "en"; // localizable string
function GetLocalizationPath()
    if ($pos == false)
    return substr($thisFile, 0, $pos+1) . "../localized/";
function FormatMessage($id, $locale, $params)
    $text = GetString($id, $locale);
    for($i = 0; $i < count($params); $i++)
        $tag = "{" . $i . "}";
        $pos1 = strpos($text, $tag);
        if($pos1 == false)
            break;
        if($pos1 > 0)
            $begin = substr($text, 0, $pos1);
        else
            $begin = "";
        $end = substr($text, $pos1 + strlen($tag));
        $text = $begin . $params[$i] . $end;
    return $text;
function GetSurroundVirtualPath()
    if (isset($_SERVER["REQUEST_URI"]))
        $path = $_SERVER["REQUEST_URI"];
        $baseuri = substr($path, 0, strrpos($path, '?') + 1);
    else
        $baseuri = $_SERVER["PHP_SELF"];
    return substr($baseuri, 0, strrpos($baseuri, '/') + 1);
function GetRootVirtualFolder()
    else
    return substr($baseuri, 0, strpos($baseuri, '/', 1));
function GetClientOS() {
    if(!isset($_SERVER['HTTP_USER_AGENT']))
        return 0;
    $agent = $_SERVER['HTTP_USER_AGENT'];
    if(strpos($agent, "Windows") != FALSE)
        return 0;
    else if(strpos($agent, "Macintosh") != FALSE)
        return 1;
    return 2;
function EscapeForHtml($str)
    $org = array("'", "\"", "\n", "<", ">");
    $repl = array("'", "&quot;", " ", "&lt;", "&gt;" );
    return str_replace($org, $repl, $str);
function GetDecimalFromLocalizedString($numberString, $locale)
    if($locale != null && $numberString != null)
        // Remove thousand separators
        $thousandSeparator = GetLocalizedString("THOUSANDSEPARATOR",
$locale);
        if($thousandSeparator != null && strlen($thousandSeparator) > 0)
            $numberString = str_replace($thousandSeparator, "",
$numberString);
        // Replace localized decimal separators with "."
        $decimalSeparator = GetLocalizedString("DECIMALSEPARATOR",
$locale);
        if($decimalSeparator != null && strlen($decimalSeparator) > 0 &&
$decimalSeparator != ".")
            $numberString = str_replace($decimalSeparator, ".",
$numberString);
    return $numberString;
On Sun, 1 Jun 2008 11:51:29 -0700 (PDT), Mauricio Villablanca
<mgvillablanca at yahoo.com> wrote:
> In order to get the shareable Markkups working first you need to update
> the
> path to your webconfig.ini file (you do that in your common.php file in
> that
> line with the $webConFigPath variable). Then modify the script so that
the
> markups will show up in your map. Also if you want to save your markups
> ina
> different folder, you need to change all references pointing to the
> 'Library:\\Masrkups\' folder.
> That's pretty much it.
> http://www.nabble.com/Shareable-markups-tp17542284p17588771.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080601/7fbdf902/attachment.html
