[mapguide-users] Mgos reading oracle column incorrectly
Zac Spitzer zac.spitzer at gmail.com
Mon Jun 2 03:49:25 EDT 2008
Can you file a bug @ http://trac.osgeo.org/fdo/ against the KingOracle Provider?
You could create a view which cast's the value as a varchar value, you
just need
to create a record under sdo_geom_metadata for the view as well.
z
On Mon, Jun 2, 2008 at 5:44 PM, Marius_360 <marius at openspatial.co.za> wrote:
> I have tested that with the VARCHAR2 and it does display the correct value.
> So the problem is the CHAR data type. Is there any way that I can get around
> this other than changing the column datatype? As I said earlier I may not
> really change the DB on the client's side.
> Marius_360 wrote:
>> I thought something like this as well, I will try this but the problem is
>> that I cannot change anything in the DB but at least this will help in
>> finding the problem.
>> zspitzer wrote:
>>> looks like its displaying the ascii value... maybe try adding a
>>> varchar2(1) column with
>>> the same value and see if that displays correctly?
>>> On Mon, Jun 2, 2008 at 5:09 PM, Marius_360 <marius at openspatial.co.za>
>>> wrote:
>>>> Hi All
>>>> I have an Oracle table with a geometry column, which I display in mgos
>>>> successfully. But one of the columns are not being read correctly, for
>>>> instance the column contains the values 'W', 'H', 'S' and so on, but
>>>> mgos is
>>>> reading it as '82', '83' ect.
>>>> This is a big problem as my layer filter is built from this column and
>>>> there
>>>> is a show info with the values of this column, so it is not working. I
>>>> am
>>>> using mgos 2.0 and Oracle 10gR2 on Windows server 2003 and IIS with the
>>>> latest Sl-king providers, the column data type is CHAR(1).
>>>> Anybody got any ideas as this is a really big problem,
>>>> Regards,
>>>> Marius
>>>> View this message in context:
>>>> http://www.nabble.com/Mgos-reading-oracle-column-incorrectly-tp17595252p17595252.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer -
>>> http://zacster.blogspot.com (My Blog)
>>> +61 405 847 168
> View this message in context: http://www.nabble.com/Mgos-reading-oracle-column-incorrectly-tp17595252p17595746.html
Zac Spitzer -
+61 405 847 168
