[mapguide-users] Mgos reading oracle column incorrectly
Marius_360 marius at openspatial.co.za
Mon Jun 2 03:52:41 EDT 2008
yes, I will file a bug. Thanks for the help, I will change it to varchar for
now, till this problem is sorted.
zspitzer wrote:
> Can you file a bug @ http://trac.osgeo.org/fdo/ against the KingOracle
> Provider?
> You could create a view which cast's the value as a varchar value, you
> just need
> to create a record under sdo_geom_metadata for the view as well.
> z
> On Mon, Jun 2, 2008 at 5:44 PM, Marius_360 <marius at openspatial.co.za>
> wrote:
>> I have tested that with the VARCHAR2 and it does display the correct
>> value.
>> So the problem is the CHAR data type. Is there any way that I can get
>> around
>> this other than changing the column datatype? As I said earlier I may not
>> really change the DB on the client's side.
>> Marius_360 wrote:
>>> I thought something like this as well, I will try this but the problem
>>> is
>>> that I cannot change anything in the DB but at least this will help in
>>> finding the problem.
>>> zspitzer wrote:
>>>> looks like its displaying the ascii value... maybe try adding a
>>>> varchar2(1) column with
>>>> the same value and see if that displays correctly?
>>>> On Mon, Jun 2, 2008 at 5:09 PM, Marius_360 <marius at openspatial.co.za>
>>>> wrote:
>>>>> Hi All
>>>>> I have an Oracle table with a geometry column, which I display in mgos
>>>>> successfully. But one of the columns are not being read correctly, for
>>>>> instance the column contains the values 'W', 'H', 'S' and so on, but
>>>>> mgos is
>>>>> reading it as '82', '83' ect.
>>>>> This is a big problem as my layer filter is built from this column and
>>>>> there
>>>>> is a show info with the values of this column, so it is not working. I
>>>>> am
>>>>> using mgos 2.0 and Oracle 10gR2 on Windows server 2003 and IIS with
>>>>> the
>>>>> latest Sl-king providers, the column data type is CHAR(1).
>>>>> Anybody got any ideas as this is a really big problem,
>>>>> Regards,
>>>>> Marius
>>>>> View this message in context:
>>>>> http://www.nabble.com/Mgos-reading-oracle-column-incorrectly-tp17595252p17595252.html
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> Zac Spitzer -
>>>> http://zacster.blogspot.com (My Blog)
>>>> +61 405 847 168
>> http://www.nabble.com/Mgos-reading-oracle-column-incorrectly-tp17595252p17595746.html
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://www.nabble.com/Mgos-reading-oracle-column-incorrectly-tp17595252p17595878.html
