[mapguide-users] Mgos reading oracle column incorrectly
Zac Spitzer
zac.spitzer at gmail.com
Mon Jun 2 03:55:14 EDT 2008
As this is FDO related, it might make sense to post this over on the
fdo-users list as well,
z
On Mon, Jun 2, 2008 at 5:52 PM, Marius_360 <marius at openspatial.co.za> wrote:
> yes, I will file a bug. Thanks for the help, I will change it to varchar for
> now, till this problem is sorted.
> zspitzer wrote:
>> Can you file a bug @ http://trac.osgeo.org/fdo/ against the KingOracle
>> Provider?
>> You could create a view which cast's the value as a varchar value, you
>> just need
>> to create a record under sdo_geom_metadata for the view as well.
>> z
>> On Mon, Jun 2, 2008 at 5:44 PM, Marius_360 <marius at openspatial.co.za>
>> wrote:
>>> I have tested that with the VARCHAR2 and it does display the correct
>>> value.
>>> So the problem is the CHAR data type. Is there any way that I can get
>>> around
>>> this other than changing the column datatype? As I said earlier I may not
>>> really change the DB on the client's side.
>>> Marius_360 wrote:
>>>> I thought something like this as well, I will try this but the problem
>>>> is
>>>> that I cannot change anything in the DB but at least this will help in
>>>> finding the problem.
>>>> zspitzer wrote:
>>>>> looks like its displaying the ascii value... maybe try adding a
>>>>> varchar2(1) column with
>>>>> the same value and see if that displays correctly?
>>>>> On Mon, Jun 2, 2008 at 5:09 PM, Marius_360 <marius at openspatial.co.za>
>>>>> wrote:
>>>>>> Hi All
>>>>>> I have an Oracle table with a geometry column, which I display in mgos
>>>>>> successfully. But one of the columns are not being read correctly, for
>>>>>> instance the column contains the values 'W', 'H', 'S' and so on, but
>>>>>> mgos is
>>>>>> reading it as '82', '83' ect.
>>>>>> This is a big problem as my layer filter is built from this column and
>>>>>> there
>>>>>> is a show info with the values of this column, so it is not working. I
>>>>>> am
>>>>>> using mgos 2.0 and Oracle 10gR2 on Windows server 2003 and IIS with
>>>>>> the
>>>>>> latest Sl-king providers, the column data type is CHAR(1).
>>>>>> Anybody got any ideas as this is a really big problem,
>>>>>> Regards,
>>>>>> Marius
>>>>>> View this message in context:
>>>>>> http://www.nabble.com/Mgos-reading-oracle-column-incorrectly-tp17595252p17595252.html
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> Zac Spitzer -
>>>>> http://zacster.blogspot.com (My Blog)
>>>>> +61 405 847 168
>>> http://www.nabble.com/Mgos-reading-oracle-column-incorrectly-tp17595252p17595746.html
>> Zac Spitzer -
>> +61 405 847 168
> View this message in context: http://www.nabble.com/Mgos-reading-oracle-column-incorrectly-tp17595252p17595878.html
Zac Spitzer -
+61 405 847 168
