[mapguide-users] Fusion with https?
Andy Morsell
amorsell at spatialgis.com
Tue Jun 3 13:51:38 EDT 2008
Paul,
I worked on this for awhile and did not make any progress. It looks the url
to fusion is being constructed correctly and all calls to the server are
being done via https. Using Fiddler 2, there are no errors. It looks like
the problem lies with the AJAX calls, as that is where the first failure
occurs. This is a bit over my head at this point, so I'm hoping that the
Fusion developers can please take a look at this. This issue is currently
effecting two of my clients and I will do whatever I can to help
trouble-shoot the problem. It is not difficult to setup a development ssl
environment with certificates, so I'm hoping that you guys can try this on
your end.
Where should I enter a Trac ticket? MGOS or Fusion?
Thanks,
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul Spencer
Sent: Monday, May 26, 2008 5:46 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Fusion with https?
Andy,
I'm not specifically aware of an issue but then I probably haven't tried it
with https. There is code in fusion.js which finds the url to fusion from
the script tag which may be at fault, I would start there.
Cheers
Paul
On 26-May-08, at 3:19 PM, Andy Morsell wrote:
> Before I dig into to this too deeply, has anyone here been able (or
> not able) to open a Fusion layout behind https? I don't have any
> trouble with regular layouts, but Fusion layouts fail. Once I know
> more about this and if it's a bug, I'll log the issue with Trac.
> Thanks.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
