[mapguide-users] fusion problem....
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Jun 4 09:09:20 EDT 2008
Ya, 1.0.6 seems to be the newest available for download.....that's one
of the 'various versions' I've tried. No luck. I tried copying the
fusion folder from a fresh install on another computer - no
luck.....then tried 1.0.6, with the templates folder from that fresh
install (because the fusion downloads have no templates, for some
reason) - no luck.
Andrew
Mike Adair wrote:
> setMetersPerUnit was introduced in Fusion 1.0.6 to resolve the
> incorrect mouse position issue so you will need to use Fusion 1.0.6.
> This is what shipped with MGOS 2.0.1.  It should be a matter of just
> replacing the fusion directory in the MG directory tree, but there
> some extra MapGuide templates in there that are missing (specifically
> the 'preview' template I believe)
> Mike
> Andrew DeMerchant wrote:
>> I'm using 2.0 - but I've tried various versions of fusion to try to
>> fix this problem. They all seem to give me the same problem now....
>> Andrew
>> Paul Spencer wrote:
>>> Are you using 2.0 or 2.0.1?  Are you using the fusion that comes
>>> with the installer or are you using another version (i.e. svn trunk)
>>> Cheers
>>> Paul
>>> On 3-Jun-08, at 3:53 PM, Andrew DeMerchant wrote:
>>>> I was silly yesterday and uninstalled my MGOS v1.02 installation. I
>>>> was running 2.0 along side....of course, uninstalling 1.0.2
>>>> completely broke 2.0. I've now (after a day) managed to get 2.0
>>>> back up and running, for the most part - but I still can't get
>>>> fusion working. I keep getting an error:
>>>> "Fusion Error:
>>>> WARNING: Exception occurred in AJAX callback.
>>>> TypeError: this.mapWidget.setMetersPerUnit is not a function
>>>> Location: undefined (223)
>>>> xx)"
>>>> Anyone?
>>>> <logo.gif>
>>>> Andrew DeMerchant
>>>> Computer Technologist
>>>> ph.1-877-2GEMTEC x.163
>>>> fax 506-453-9470
>>>> GEMTEC Limited
>>>> 191 Doak Road
>>>> Fredericton, NB, Canada
>>>> E3C 2E6
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>     *Andrew DeMerchant*
>> *Computer Technologist*
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
