[mapguide-users] Interaction between multiple Viewer Instances
Ralf Comouth ralf.comouth at vib-weinhold.com
Wed Jun 4 15:11:27 EDT 2008
Hi Jason,
I already checked the Fusion widget for the overview map, but it is not
exactly what I was looking for.
But I think the direction Kenneth has given could be the right one.
Thanks and regards
Ralf
JasonBirch wrote:
> Hi Ralf!
> No need to apologize for your english; it's better than many north
> americans' :)
> I'm not sure about integration, but you can look at the overview map
> widget in Fusion to give you an idea where to start.  Once you have the
> two map instances running, I guess you'd have to follow the directions
> that Kenneth has given?
> Jason
> -----Original Message-----
> From: Ralf Comouth
> Subject: [mapguide-users] Interaction between multiple Viewer Instances
> The idea is to use the selection in the chart to zoom to the real map.
> Now my problem is the "interaction" between these two instances of the
> Mapserver.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Interaction-between-multiple-Viewer-Instances-tp17641488p17654354.html
