[mapguide-users] MGOS2.0.1 & Raster Files Performance
Gunter Becker
gunter.becker at CSOGIS.DE
Thu Jun 5 09:05:11 EDT 2008
Hi Max,
please habe a look at http://trac.osgeo.org/fdo/wiki/FdoGdalNotes Creating
Tile Index Config Files . Maybe you can build a tile index for your
ecw-files. That will minimiz the file access. But I don't know if this works
with ecw.
Gunter
max_samart wrote:
> Hi All,
> I am using PHP+Apache+Windows Server 2003 and i have around
> 50 ecw files in one folder, i created the Image Feature Source using the
> OSGeo.Gdal FDO provider and able to view the raster data overlaid with the
> vector data but the problem is about the performance and sometime it use
> to fail to stylize layer due to Cannot create any more connections to the
> OSGeo.Gdal FDO provider as well as the server also use to give the error
> Please try your operation later as the resource was busy:
> Library://Raster/Data/Images.FeatureSource .
> How to solve the issue.
> Thks
> Max !!
> Error
> <2008-06-05T15:41:04> Administrator
> Error: Failed to stylize layer: Image
> Cannot create any more connections to the OSGeo.Gdal FDO provider.
> StackTrace:
> - MgMappingUtil.StylizeLayers line 775 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\mapping\MappingUtil.cpp Failed
> <2008-06-05T15:42:26> Administrator
> Error: Please try your operation later as the resource was busy:
> StackTrace:
> - MgResourceServiceHandler.ProcessOperation line 80 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
> - MgOpDeleteResource.Execute line 97 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\OpDeleteResource.cpp
> - MgServerResourceService.DeleteResource line 750 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ServerResourceService.cpp
> - MgServerFeatureService.NotifyResourcesChanged line 1457 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\feature\ServerFeatureService.cpp
> - MgFdoConnectionManager.RemoveCachedFdoConnection line 1006 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\common\manager\FdoConnectionManager.cpp Please
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MGOS2.0.1---Raster-Files-Performance-tp17668649p17669360.html
