[mapguide-users] fusion legend incorrect...
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Jun 5 09:45:14 EDT 2008
I'm using the built-in templates, yes.....I'm going to end up modifying
one of them to fit my needs though. Tooltips are working fine for me...I
just have tooltips for one point layer - works fine.
Berdel, Brian wrote:
> That is strange my regular layer groups are fine. However, I just
> noticed that if I create my own fusion file (not from template...),
> this does not occur. There is also an issue with tooltips not working
> and the template files.
> Are you using the templates in Mapguide Studio?
> Brian
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Thursday, June 05, 2008 9:08 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] fusion legend incorrect...
> Mine's not a base layer group - I don't have any, in fact. Just a
> regular layer group....
> Andrew
> It occurs for me as well, but only for base layer groups.
> Brian Berdel
> McMahon Associates, Inc.
> p: 215.283.9444
> www.mcmtrans.com <http://www.mcmtrans.com>
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> DeMerchant
> *Sent:* Thursday, June 05, 2008 8:40 AM
> *Subject:* [mapguide-users] fusion legend incorrect...
> I've finally gotten fusion back up and running - but I'm noticing
> something odd. I've got a couple of groups in my map...if I set one of
> them to not be displayed on the map initially, sure enough, it's not
> displayed.....but here's the odd part - it shows in the legend that it
> IS displayed. What I mean is, it shows up in the legend with a check
> box, that is checked. If I turn it off, the map reloads but looks the
> same....if I then turn it on again, my group is displayed. So
> basically, the only way for me to turn on this group is to turn it
> 'off' and then on again. Anyone else having this issue?
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
