FW: [mapguide-users] Custom Symbols...
Martin Morrison martin.morrison at edsi.com
Thu Jun 5 11:15:06 EDT 2008
Any thoughts?
Thanks,
Martin
-----Original Message-----
Sent: Wednesday, June 04, 2008 8:02 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Custom Symbols...
I have pasted the relevant parts of each file below.  I have both (line
and symbol) on the same layer with I thought the same scales.
>From the layer definition...
    <VectorScaleRange>
      <MinScale>100</MinScale>
   <CompositeTypeStyle>
    <CompositeRule>
     <LegendLabel>'Interstate Highways'</LegendLabel>
     <CompositeSymbolization>
      <SymbolInstance>
<ResourceId>Library://Mecklenburg_County/Layers/Interstate_Highway.Symbo
lDefinition</ResourceId>
       <ParameterOverrides>
       	<Override>
       	 <SymbolName>Shield</SymbolName>
       	 <ParameterIdentifier>ROADNAME</ParameterIdentifier>
       	 <ParameterValue>ROUTE</ParameterValue>
       	</Override>
       </ParameterOverrides>
      </SymbolInstance>
     </CompositeSymbolization>
    </CompositeRule>
   </CompositeTypeStyle>
    </VectorScaleRange>
>From the symbol definition...
  <SimpleSymbol>
    <SimpleSymbolDefinition>
      <Name>Outline</Name>
	  <Graphics>
		<Path>
			<Geometry>M 0.0,0.0 H 5.0 Z</Geometry>
			<LineColor>FF000000</LineColor>
			<LineWeight>2.0</LineWeight>
		</Path>
	  </Graphics>
	  <LineUsage>
		<VertexControl>'OverlapWrap'</VertexControl>
		<StartOffset>0</StartOffset>
		<Repeat>5.0</Repeat>
		<VertexAngleLimit>180.0</VertexAngleLimit>
	  </LineUsage>
	  <ParameterDefinition/>
    </SimpleSymbolDefinition>
    <RenderingPass>0</RenderingPass>
  </SimpleSymbol>
  <SimpleSymbol>
      <Name>Inner</Name>
	  <Graphics>
		<Path>
			<LineColor>FF800000</LineColor>
			<LineWeight>0.9</LineWeight>
		</Path>
	  </Graphics>
	  <LineUsage>
	  </LineUsage>
    <RenderingPass>1</RenderingPass>
  </SimpleSymbol>
  <SimpleSymbol>
	  <Name>Shield</Name>
	  <Graphics>
    <Image>
      <Content>
iVBORw0KGgoAAAANSUhEUgAAAE0AAAA2CAMAAAC1MuSAAAAALHRFWHRDcmVhdGlvbiBUaW1l
AEZy
aSAzMCBNYXkgMjAwOCAxMzo0OTo0NyAtMDUwMBH+gTkAAAAHdElNRQfYBR4ROShsSnc5AAAA
CXBI
WXMAAAsSAAALEgHS3X78AAAABGdBTUEAALGPC/xhBQAAACpQTFRFxt7G///3////pc73hITG
AAD/
Y2PG56WE/wAA52NC56XG50JC54SE52OEjX+r1gAAAAF0Uk5TAEDm2GYAAAFcSURBVHja1dfb
koMg
DAZgf0KVtd33f91FTgUUAZObzU2diX6TgFRYFhdY7qOTR5GHUgCat6KXt+lSO+J4DjUUcp00
Cuz7
zEUUZuOWAjN74wlg/zU2tgbo8nmr9to9YD47qvBSjO2c94m90GCY8S3OXn0kNXZp5p04pXa2
loqz
v5uI5jiJRo35EdViqyKNRg1h/bHDtpoWvEhAXnuJBP0DbZXS3PumRTQEjYQ0v7JktLROJTCK
msjA
+UmQGjiE/16RVrVKmkCrsVGZ4pA+qALFkco1bnEoNyK8aaVqkwTO0tfn/RtDOz4t1ebyea/V
1pLH
0QljcFfYgodv3SXmZ2Keo3oGOFwT89zU2K2qjfmxm+D0Lea54W6pg8VuR1aZrk4wN+V1213R
L2zU
0zRUWMYpaoEUTkRjWPKuQJq2Mq8A10DNWt6LR0/Sx1BROvTNWyWYnR8fUgmEjJSLY9If47Y6
+jho
AQAAAAAASUVORK5CYII=
      </Content>
      <SizeX>8.0</SizeX>
      <SizeY>8.0</SizeY>
      <SizeScalable>True</SizeScalable>
      <Angle>0.0</Angle>
      <PositionX>0.0</PositionX>
      <PositionY>0.0</PositionY>
    </Image>
		<Text>
		  <ResizeControl>'AddToResizeBox'</ResizeControl>
		  <Content>%ROADNAME%</Content>
		  <FontName>'Arial'</FontName>
		  <Height>4</Height>
		  <PositionX>0</PositionX>
		  <PositionY>0</PositionY>
		  <HorizontalAlignment>'Center'</HorizontalAlignment>
		  <VerticalAlignment>'Halfline'</VerticalAlignment>
		  <TextColor>FFFFFFFF</TextColor>
		</Text>
	  </Graphics>
	  <ResizeBox>
	  	<SizeX>6</SizeX>
	  	<SizeY>6</SizeY>
	  	<GrowControl>'GrowInX'</GrowControl>
	  </ResizeBox>
	  <LineUsage>
	  	<AngleControl>'FromAngle'</AngleControl>
	  	<VertexControl>'OverlapNoWrap'</VertexControl>
	  	<Angle>0</Angle>
	  	<StartOffset>50</StartOffset>
	  	<EndOffset>50</EndOffset>
	  	<Repeat>100</Repeat>
	  </LineUsage>
	  <ParameterDefinition>
	  	<Parameter>
	  	 <Identifier>ROADNAME</Identifier>
	  	 <DefaultValue>5</DefaultValue>
	  	 <DisplayName>ROADNAME</DisplayName>
	  	 <Description>ROADNAME</Description>
	  	 <DataType>Integer</DataType>
	  	</Parameter>
	  </ParameterDefinition>
	<RenderingPass>2</RenderingPass>
  </SimpleSymbol>
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Tuesday, June 03, 2008 5:08 PM
To: MapGuide Users Mail List
There is not enough information to answer this. Is the rest of the road
drawn using the same symbol definition, or is it a separate one (or even
a separate layer?). Normally the scale range for visibility is specified
for the whole layer, so if you are seeing this with data on the same
layer, it could be a bug.
Traian
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Martin Morrison
> Sent: Tuesday, June 03, 2008 3:38 PM
> Ok, next question...
> I have the symbols working, they look great.  The road symbols just
> turn
> off when I zoom out past about 7000 even though the road still shows
up
> with it's style.  I don't see a parameter that controls how far in and
> out the symbol displays.  Where should this be changed at?
> Thanks,
> Martin
> Stanev
> Sent: Sunday, June 01, 2008 7:35 PM
> Hi Martin,
> You are using incorrect format for the Content tag. The
> "data:image/png;base64," piece is not necessary, just the png content
> converted to base64.
> Here is an example of correct usage:
> <?xml version="1.0" encoding="UTF-8"?>
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="SymbolDefinition-1.0.0.xsd"
> version="1.0.0">
>   <Name>Symbol</Name>
>   <Graphics>
>     <Image>
>       <Content>
iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAIAAAD8GO2jAAAAAXNSR0IArs4c6QAAAARnQU1
> B
> AACx
jwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpRPAAAAMl
> J
> REFU
SEvtlusOgCAIhe3Ne3MrSIeBaIittRz+ae18ykVYYpi8ABDDGvwtxEP82Lu6OwMECcCXkY5
> b
> ArwY
xBkMMM4oXS0BRhgskBWAjSGlSR3AGPuvFyvSupKEKgAZYLDZwgJCq5RRF0BWR1xmmAGaOmX
> Y
> AG31
zDAAetVVhhaDHwBR+baL8IJCAYslbUhTbHNthtpxX/BUzHzsWG9yfa4NQ8aNhmNQxyzqapl
> m
> dYnx
> 8NgyeHZaa8Lg5ahOfJVc5K6eGCeAjySOXzZKzdKePStlhwAAAABJRU5ErkJggg==
>       </Content>
>       <SizeX>8.0</SizeX>
>       <SizeY>8.0</SizeY>
>       <Angle>0.0</Angle>
>     </Image>
>   </Graphics>
>   <PointUsage>
>     <Angle>0.0</Angle>
>     <OriginOffsetX>0.0</OriginOffsetX>
>     <OriginOffsetY>0.0</OriginOffsetY>
>   </PointUsage>
> Thanks,
> Traian
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin
> Morrison
> Sent: Friday, May 30, 2008 4:17 PM
> Subject: [mapguide-users] Custom Symbols...
> I'm trying to embed a PNG into a custom symbol.  When I use the code
> below I get the error shown at the bottom.  If I remove this section
it
> works (without my PNG of course).  How should the <IMAGE> tag be used?
> Any clues?
> Thanks,
> Martin
> ****************CODE Snippet*******************
>   <SimpleSymbol>
>                   <Name>Shield</Name>
>                   <Graphics>
>                                 <Image>
<Content>data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAE0AAAA2CAMAAAC1
> M
uSAAAAALHRFWHRDcmVhdGlvbiBUaW1lAEZyaSAzMCBNYXkgMjAwOCAxMzo0OTo0NyAtMDUw
> M
BH+gTkAAAAHdElNRQfYBR4ROShsSnc5AAAACXBIWXMAAAsSAAALEgHS3X78AAAABGdBTUEA
> A
LGPC/xhBQAAACpQTFRFxt7G///3////pc73hITGAAD/Y2PG56WE/wAA52NC56XG50JC54SE
> 5
2OEjX+r1gAAAAF0Uk5TAEDm2GYAAAFcSURBVHja1dfbkoMgDAZgf0KVtd33f91FTgUUAZOb
> z
U2diX6TgFRYFhdY7qOTR5GHUgCat6KXt+lSO+J4DjUUcp00Cuz7zEUUZuOWAjN74wlg/zU2
> t
gbo8nmr9to9YD47qvBSjO2c94m90GCY8S3OXn0kNXZp5p04pXa2loqzv5uI5jiJRo35EdVi
> q
yKNRg1h/bHDtpoWvEhAXnuJBP0DbZXS3PumRTQEjYQ0v7JktLROJTCKmsjA+UmQGjiE/16R
> V
rVKmkCrsVGZ4pA+qALFkco1bnEoNyK8aaVqkwTO0tfn/RtDOz4t1ebyea/V1pLH0QljcFfY
> g
odv3SXmZ2Keo3oGOFwT89zU2K2qjfmxm+D0Lea54W6pg8VuR1aZrk4wN+V1213RL2zU0zRU
> W
MYpaoEUTkRjWPKuQJq2Mq8A10DNWt6LR0/Sx1BROvTNWyWYnR8fUgmEjJSLY9If47Y6+jho
> A
> QAAAAAASUVORK5CYII%3D</Content>
>                                  <SizeX>10</SizeX>
>                                  <SizeY>10</SizeY>
>                                 </Image>
> ****************Error************************
> C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\Php>php.exe
> "C:\Mapguide_Road_Symbols\loadresources.php" "C:\Mapguide_Roa
> d_Symbols" Library://Mecklenburg_County/Layers/
> Reading resources files from 'C:\Mapguide_Road_Symbols'
> Writing C:\Mapguide_Road_Symbols\Primary_Road.SymbolDefinition.xml to
> Library://Mecklenburg_County/Layers/Primary_Road.SymbolDefinit
> ion
> Writing C:\Mapguide_Road_Symbols\Roads.LayerDefinition.xml to
> Library://Mecklenburg_County/Layers/Roads.LayerDefinition
> Writing C:\Mapguide_Road_Symbols\Roads.SymbolDefinition.xml to
> Library://Mecklenburg_County/Layers/Roads.SymbolDefinition
> An exception occurred in DB XML component.
> Error: XML Indexer:  Parse error in document at line, 71, char 28.
> Parser message: Datatype error: Type:InvalidDatatypeValueExceptio
> n, Message:Value
'URI:(data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAE0AAAA2CAMAAAC1MuS
> A
gMjAwOCAxMzo0OTo0NyAtMDUwMBH+gTkAAAAHdElNRQfYBR4ROShsSnc5AAAACXBIWXMAAA
> s
3hITGAAD/Y2PG56WE/wAA52NC56XG50JC54SE52OEjX+r1gAAAAF0Uk5TAEDm2GYAAAFcSU
> R
> BVHja1dfbkoMgDAZgf0KVtd33f91FTgUUAZObzU2diX6TgFRYFhdY7qOTR5G
HUgCat6KXt+lSO+J4DjUUcp00Cuz7zEUUZuOWAjN74wlg/zU2tgbo8nmr9to9YD47qvBSjO
> 2
> c94m90GCY8S3OXn0kNXZp5p04pXa2loqzv5uI5jiJRo35EdViqyKNRg1h/bH
DtpoWvEhAXnuJBP0DbZXS3PumRTQEjYQ0v7JktLROJTCKmsjA+UmQGjiE/16RVrVKmkCrsV
> G
Ygodv3SXmZ2Keo3oGOFwT89zU2K2qjfmxm+D0Lea54W6pg8VuR1aZrk4wN+V1213RL2zU0z
> R
> LY9If47Y6+jhoAQAAAAAASUVORK5CYII%3D)' is not encoded in Base64 .
> Exception occurred in method
MgResourceDefinitionManager.UpdateDocument
> at line 601 in file d:\buildforgeprojects\mapguide_open_sour
ce_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceDefiniti
> o
> nManager.cpp
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
