[mapguide-users] MGOS2.0.1 & Raster Files Performanc
Zac Spitzer zac.spitzer at gmail.com
Thu Jun 5 21:58:11 EDT 2008
I think the problem with the crashing isn't caught by the FDO unit
tests because the problem happens after a while and the unit tests
might not be running longer enough
if anyone want's to reproduce the problem, there is some good sample
the imagery here
which always eventually crashes mapguide
http://www.unearthedoutdoors.net/global_data/true_marble/download
z
On Fri, Jun 6, 2008 at 2:58 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> G.E.O.-Consulting / Hans Mörschell wrote:
>> Hi,
>> We experience the same problems using MGOS2.0.1 with IIS on MS Server 2003
>> and MS Server 2008 and an ASP application (FDO Provider). We use Tiff and
>> MrSID files of different sizes and resolutions but the errors are always
>> the
>> same as described (cannot stylize layer, out of memory, no more
>> connections
>> and so on).
>> We now have some kind of "monitor" application and restart the mgserver
>> process if necessary, but this is not a really good solution because
>> throwing the error "no more connections..." the mgserver process does not
>> crash rather "refuses" to render the images.
>> Furthermore restarting mgserver resulting in loss of session data is
>> really
>> annoying so we are looking now for some workaround, does anybody have any
>> idea what can be done ?
>> Possible ideas might be:
>>  - using an external image server, is there any ?
>>  - recovering sessions, is there any possibility ?
> Folks,
> I think the best might be to lock me, a mapguide developer with good
> debugging skills, and perhaps someone who can demonstrate the problem in
> a room for a day or two.   I don't have the mapguide skills to debug this
> in the mapguide context, and things seem to work fine with the FDO
> unit tests.  If there is a mapguide developer in the Ottawa/Montreal/Toronto
> region that could spare a day or two for this work I would be willing to
> visit.
> I have stopped reviewing the various raster related emails on this list very
> closely since a lot of problems seem to be related to deploying the mrsid
> plugin or related to missing/extra slashes in paths.  But if folks are
> having the discussed problems with tiff files then the problem is pretty
> core.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
