[mapguide-users] FM Tiling Engine on MGOS 2.0.1
Rahul unicorn_admirer at yahoo.com
Thu Jun 5 11:47:47 EDT 2008
         I think the mapviewernet\bin directory will be with ASP.NET +IIS setting but i am using  PHP+Apache hence in my case its only mapviewerphp and mapagent directory.
C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapviewerphp (No bin)
C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapagent
Max !
----- Original Message ----
To: mapguide-users at lists.osgeo.org
Sent: Thursday, June 5, 2008 9:09:32 PM
Subject: Re: [mapguide-users] FM Tiling Engine on MGOS 2.0.1
Try copying all the dlls from the mapviewernet\bin directory and overwrite
the ones installed by the Tiling Engine and see if that helps.
- Jackie
max_samart wrote:
> Hi All,
>              I am using PHP+Apache+Windows Server 2003 ,and i would like
> to enquire that whether FM Tiling Engine supports MGOS 2.0.1 on the above
> configuration and if so then what kind of dll files should be copied
> fromMapGuideOpenSource2.0\WebServerExtension\www into the Websoft
> Developers\FacilitiesMap Tiling Engine Folder, I already configured the
> FMTilingEngine.exe.config file as well as replaced the webconfig.ini file.
> Thks
> Max !
> mapguide-users mailing list
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/FM-Tiling-Engine-on-MGOS-2.0.1-tp17663298p17670722.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080605/3c890716/attachment.html
