[mapguide-users] FM Tiling Engine on MGOS 2.0.1
Kori Maleski
kori.maleski at gmail.com
Thu Jun 5 12:33:40 EDT 2008
The Tiling Engine will work with PHP+Apache, but requires the .NET dll's in
order to work.
Try with running it with the default installation, but you need to set the
new 2.0.1 parameter in the config file.
If that fails, install the 2.0.1 .NET Webextensions on a test machine and
copy the required dll's to the Tiling Engine install directory.
If that fails, you will have to wait for a new release.
Cheers,
Kori Maleski
On Thu, Jun 5, 2008 at 8:47 AM, Rahul <unicorn_admirer at yahoo.com> wrote:
> Hi,
> I think the mapviewernet\bin directory will be with *ASP.NET<http://asp.net/>+IIS
> * setting but i am using PHP+Apache hence in my case its only
> mapviewerphp and mapagent directory.
> C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapviewerphp
> *(No bin)*
> C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapagent
> Max !
> ----- Original Message ----
> From: Jackie C. Ng <jumpinjackie at gmail.com>
> To: mapguide-users at lists.osgeo.org
> Sent: Thursday, June 5, 2008 9:09:32 PM
> Subject: Re: [mapguide-users] FM Tiling Engine on MGOS 2.0.1
> Try copying all the dlls from the mapviewernet\bin directory and overwrite
> the ones installed by the Tiling Engine and see if that helps.
> - Jackie
> max_samart wrote:
> > Hi All,
> > I am using PHP+Apache+Windows Server 2003 ,and i would like
> > to enquire that whether FM Tiling Engine supports MGOS 2.0.1 on the above
> > configuration and if so then what kind of dll files should be copied
> > fromMapGuideOpenSource2.0\WebServerExtension\www into the Websoft
> > Developers\FacilitiesMap Tiling Engine Folder, I already configured the
> > FMTilingEngine.exe.config file as well as replaced the webconfig.ini
> file.
> > Thks
> > Max !
> > mapguide-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://themapguyde.blogspot.com
> http://www.linkedin.com/in/jackieng
> http://www.nabble.com/FM-Tiling-Engine-on-MGOS-2.0.1-tp17663298p17670722.html
> Sent from the MapGuide Users mailing list archive at Nabble.com<http://nabble.com/>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080605/e16adfe4/attachment.html
