[mapguide-users] FM Tiling Engine on MGOS 2.0.1
Kori Maleski
kori.maleski at gmail.com
Thu Jun 5 12:35:18 EDT 2008
For the default install, you will also have to replace the webconfig.ini
with the 2.0.1 version.
On Thu, Jun 5, 2008 at 9:33 AM, Kori Maleski <kori.maleski at gmail.com> wrote:
> The Tiling Engine will work with PHP+Apache, but requires the .NET dll's
> in order to work.
> Try with running it with the default installation, but you need to set the
> new 2.0.1 parameter in the config file.
> If that fails, install the 2.0.1 .NET Webextensions on a test machine and
> copy the required dll's to the Tiling Engine install directory.
> If that fails, you will have to wait for a new release.
> Cheers,
> Kori Maleski
> On Thu, Jun 5, 2008 at 8:47 AM, Rahul <unicorn_admirer at yahoo.com> wrote:
>> Hi,
>> I think the mapviewernet\bin directory will be with *ASP.NET<http://asp.net/>+IIS
>> * setting but i am using PHP+Apache hence in my case its only
>> mapviewerphp and mapagent directory.
>> C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapviewerphp *(No
>> bin)*
>> C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapagent
>> Max !
>> ----- Original Message ----
>> From: Jackie C. Ng <jumpinjackie at gmail.com>
>> To: mapguide-users at lists.osgeo.org
>> Sent: Thursday, June 5, 2008 9:09:32 PM
>> Subject: Re: [mapguide-users] FM Tiling Engine on MGOS 2.0.1
>> Try copying all the dlls from the mapviewernet\bin directory and overwrite
>> the ones installed by the Tiling Engine and see if that helps.
>> - Jackie
>> max_samart wrote:
>> > Hi All,
>> > I am using PHP+Apache+Windows Server 2003 ,and i would like
>> > to enquire that whether FM Tiling Engine supports MGOS 2.0.1 on the
>> above
>> > configuration and if so then what kind of dll files should be copied
>> > fromMapGuideOpenSource2.0\WebServerExtension\www into the Websoft
>> > Developers\FacilitiesMap Tiling Engine Folder, I already configured the
>> > FMTilingEngine.exe.config file as well as replaced the webconfig.ini
>> file.
>> > Thks
>> > Max !
>> > _______________________________________________
>> > mapguide-users mailing list
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://themapguyde.blogspot.com
>> http://www.linkedin.com/in/jackieng
>> View this message in context:
>> http://www.nabble.com/FM-Tiling-Engine-on-MGOS-2.0.1-tp17663298p17670722.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com<http://nabble.com/>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080605/db9728fe/attachment.html
