[mapguide-users] What error is it?
Zac Spitzer zac.spitzer at gmail.com
Thu Jun 5 23:55:32 EDT 2008
This problem happens intermittently with Mapguide Opensource 2.0 as well
BTW, This is the wrong forum for MGE questions, you should try the
Autodesk groups
On Fri, Jun 6, 2008 at 1:41 PM, Eric123 <erictsn at cadbeyond.com> wrote:
> I installed MapGuide Enterprise 2009 to CentOS 4.6.; Recently I cannot
> upload/ modify the map to server. I can only create folder through MapGuide
> Studio. I checked the error.log of MapGuide server. There is message as
> below:
> <2008-06-06T05:41:23>
>  Error: A stream IO exception occurred.
>       pThe TCP/IP protocol is mismatched between the Server and Web
> Extensions.  Please install the same version of Server and Web Extensions.
>  StackTrace:
>  - MgOperationThread.ProcessMessage line 276 file OperationThread.cpp
>  - MgStreamParser.ParseStreamHeader line 91 file System/StreamParser.cpp
> The TCP/IP protocol is mismatched between the Server and Web Extensions.
> View this message in context: http://www.nabble.com/What-error-is-it--tp17684019p17684019.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
