[mapguide-users] Dynamic Load WebLayout
nclayton
nclayton at gmail.com
Fri Jun 6 11:23:09 EDT 2008
I just got this to finally work.
I had to return the ResourceId generated inside the function to use in
mainframe.php
so now my code inside mainframe.php that sets up $webLayout looks like this:
$resourceSrvc = $site->CreateService(MgServiceType::ResourceService);
$rid = loadWebLayout($sessionId,$resourceSrvc);
$webLayout = new MgWebLayout($resourceSrvc, $rid);
It's odd that you cannot just create another ResourceID that references that
resource...or maybe it isn't. Is there some sort of "locking" mechanism on
resources when resourceIdentifiers are created?
Kenneth Skovhede, GEOGRAF A/S wrote:
> I belive that MapGuide runs in the "System" account, so it has full
> access.
> Are you certain that $sid is the same sessionid as the connection has?
> You cannot save to another session (perhaps the Administrator can?).
> Regards, Kenneth Skovhede, GEOGRAF A/S
> nclayton skrev:
>> I am having this exact same problem. I am using php and the ajaxviewer.
>> I was able to store the weblayout in Library:// but get 'Permission
>> denied'
>> when trying to store in Session:
>> Here is my code:
>> function loadWebLayout($sid,$svc){
>> $lyt = <<<XML
>> weblayout xml here...
>> XML;
>> $dom = new domDocument;
>> $dom->loadXML($lyt);
>> $def = "Session:" . $sid . "//standard.WebLayout";
>> $rid = new MgResourceIdentifier($def);
>> $dat = $dom->saveXML();
>> $src = new MgByteSource($dat,strlen($dat));
>> $src->SetMimeType(MgMimeType::Xml);
>> $svc->SetResource($rid,$src->GetReader(),null);
>> should the IUSR_* account have write/modify rights to the session folder
>> in
>> the repository perhaps?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Dynamic-Load-WebLayout-tp15950704p17694835.html
