[mapguide-users] Dynamic Load WebLayout
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Jun 6 11:33:46 EDT 2008
MapGuide restricts you from writing into another session repository, so
it is intentional.
When you call "CreateSession" you get a clean repository, and cannot
interact with the other sessions repository, even if you have the
correct path.
Regards, Kenneth Skovhede, GEOGRAF A/S
nclayton skrev:
> I just got this to finally work.
> I had to return the ResourceId generated inside the function to use in
> mainframe.php
> so now my code inside mainframe.php that sets up $webLayout looks like this:
> $resourceSrvc = $site->CreateService(MgServiceType::ResourceService);
> $rid = loadWebLayout($sessionId,$resourceSrvc);
> $webLayout = new MgWebLayout($resourceSrvc, $rid);
> It's odd that you cannot just create another ResourceID that references that
> resource...or maybe it isn't. Is there some sort of "locking" mechanism on
> resources when resourceIdentifiers are created?
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I belive that MapGuide runs in the "System" account, so it has full
>> access.
>> Are you certain that $sid is the same sessionid as the connection has?
>> You cannot save to another session (perhaps the Administrator can?).
>> nclayton skrev:
>>> I am having this exact same problem. I am using php and the ajaxviewer.
>>> I was able to store the weblayout in Library:// but get 'Permission
>>> denied'
>>> when trying to store in Session:
>>> Here is my code:
>>> function loadWebLayout($sid,$svc){
>>> $lyt = <<<XML
>>> weblayout xml here...
>>> XML;
>>> $dom = new domDocument;
>>> $dom->loadXML($lyt);
>>> $def = "Session:" . $sid . "//standard.WebLayout";
>>> $rid = new MgResourceIdentifier($def);
>>> $dat = $dom->saveXML();
>>> $src = new MgByteSource($dat,strlen($dat));
>>> $src->SetMimeType(MgMimeType::Xml);
>>> $svc->SetResource($rid,$src->GetReader(),null);
>>> should the IUSR_* account have write/modify rights to the session folder
>>> in
>>> the repository perhaps?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080606/ceeabcbc/attachment.html
