[mapguide-users] Mgos rounding number type column in Oracle problem
Zac Spitzer zac.spitzer at gmail.com
Mon Jun 9 03:46:04 EDT 2008
how is the column defined?
i think float and double would not be rounded
z
On Mon, Jun 9, 2008 at 5:20 PM, Marius_360 <marius at openspatial.co.za> wrote:
> Hi all,
> I've got another problem with oracle columns being read incorrectly. I
> create a point layer in MgOS 2.0 and then read the rotation for the symbol
> from a number type column, which contains values like 0.2568 and 3.58769,
> which is the angle for that entity in radians. Now the problem is MgOS is
> rounding the values to the nearest whole number, which is a major problem
> when converting the angle to degrees, as the values are now 0 and 4 and that
> causes a major difference in the degree angle.
> I am using Studio 2008 to author, DB is Oracle 10R2, MgOS 2.0 with newest SL
> King provider.
> Has anyone seen this before? This is quite an urgent problem, would be nice
> if this could be fixed without a time consuming work-around!
> Thanks in advance
> Marius
> View this message in context: http://www.nabble.com/Mgos-rounding-number-type-column-in-Oracle-problem-tp17727692p17727692.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
