[mapguide-users] Mgos rounding number type column in Oracle problem
Marius_360
marius at openspatial.co.za
Mon Jun 9 03:20:45 EDT 2008
Hi all,
I've got another problem with oracle columns being read incorrectly. I
create a point layer in MgOS 2.0 and then read the rotation for the symbol
from a number type column, which contains values like 0.2568 and 3.58769,
which is the angle for that entity in radians. Now the problem is MgOS is
rounding the values to the nearest whole number, which is a major problem
when converting the angle to degrees, as the values are now 0 and 4 and that
causes a major difference in the degree angle.
I am using Studio 2008 to author, DB is Oracle 10R2, MgOS 2.0 with newest SL
King provider.
Has anyone seen this before? This is quite an urgent problem, would be nice
if this could be fixed without a time consuming work-around!
Thanks in advance
Marius
View this message in context: http://www.nabble.com/Mgos-rounding-number-type-column-in-Oracle-problem-tp17727692p17727692.html
