[mapguide-users] how to set selected feature at client in
fusion???
foolfish
xjimmyshcn at sohu.com
Mon Jun 9 21:52:54 EDT 2008
thanks for reply~ Berdel
i meet the same problem after use SetSelectionXML() at client.
i think the selection.ToXml() at server has problem in fusion,perhaps the
format is not valid for fusion.
Berdel, Brian wrote:
> There are two ways to do it...My preferred way is to use the
> MapguideViewweAPI.js file located under
> fusion/MapGuide/MapGuideViewerAPI.js
> This has the SetSelectionXML Function in it and it also automatically
> zooms and refreshes the map once called. Place this javascript in your
> task frame page. I include the MapGuideViewerAPI.js in my fusion
> application template.
> function GetParent()
> if (popup) {
> return opener;
> } else
> if (parent.Fusion) {
> return parent;
> } else if (parent.parent.Fusion) {
> return parent.parent;
> return null;
> function(mapName, sel)
> var map = GetParent().Fusion.getMapByName(mapName);
> GetParent().SetSelectionXML(sel);
> The one issue I did run into is that when grabbing the selectionXML
> selectionXML = selection.ToXml();
> the XML was incorrect...For the layername it was bringing in only the
> second part of the layer name (i.e. Parcels instead of Default:Parcels)
> which was giving an error in fusion when setting the selection. For
> right now, I am just replacing the string after calling selection.ToXML
> There is also a setSelection() function in fusion, but I haven't tried it
> yet...
> Thanks,
> Brian Berdel
> McMahon Associates, Inc.
> p: 215.283.9444
> www.mcmtrans.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of foolfish
> Sent: Sunday, June 08, 2008 10:17 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] how to set selected feature at client in
> fusion???
> my problem is in tradition method (not use fusion), i can select feature
> at
> server, and display the selected feature at client。
> but in fusion,the follow line is failed:
> parent.parent.SetSelectionXML(selectionXML);
> parent.parent.mapFrame.Refresh();
> my question is how to setSelection at client in fusion?:confused:
> [at server]:i define a function to select Feature,and return a
> selectionXML
> public void CreateSelectionXML(String queryLayer, String
> queryString,String
> map_name)
> MgResourceService resService =
> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
> MgFeatureService featureService =
> (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
> MgMap map = new MgMap();
> map.Open(resService, map_name);
> MgLayer layer = (MgLayer)map.GetLayers().GetItem(queryLayer);
> MgResourceIdentifier resId = new
> MgResourceIdentifier(layer.GetFeatureSourceId());
> MgFeatureQueryOptions queryOption = new MgFeatureQueryOptions();
> queryOption.SetFilter(queryString);
> MgFeatureReader featureReader =
> featureService.SelectFeatures(resId,
> queryLayer, queryOption);
> MgSelection selection = new MgSelection(map);
> selection.AddFeatures(layer, featureReader, 0);
> OutputSelectionInHTML(selection, featureService, queryLayer);
> [at client]:
> string sessionID = Request.Form.Get("SESSION");;
> String queryString = "ID='"+ Request.Form.Get("ID"); +"'";
> String queryLayer = Request.Form.Get("LAYER_NAME");
> String map_name = Request.Form.Get("MAP_NAME");
> InitializeWebTier(Request);
> onnectToServer(sessionID);
> CreateSelectionXML(queryLayer,queryString,map_name );
> String selectionXML = utility.SelectionXML;
> <script type="text/javascript" >
> function onPageLoad() {
> var selectionXML = '<% = selectionXML %>';
> </script>
> <body onload="onPageLoad()" >
> </body>
> http://www.nabble.com/how-to-set-selected-feature-at-client-in-fusion----tp17725343p17725343.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/how-to-set-selected-feature-at-client-in-fusion----tp17725343p17746181.html
