[mapguide-users] how to set selected feature at client in fusion???
Berdel, Brian brian.berdel at mcmtrans.com
Mon Jun 9 10:26:21 EDT 2008
There are two ways to do it...My preferred way is to use the MapguideViewweAPI.js file located under fusion/MapGuide/MapGuideViewerAPI.js
This has the SetSelectionXML Function in it and it also automatically zooms and refreshes the map once called.   Place this javascript in your task frame page.  I include the MapGuideViewerAPI.js in my fusion application template.
      function GetParent()
  if (popup) {
      return opener;
    } else
    if (parent.Fusion) {
        return parent;
    } else if (parent.parent.Fusion) {
        return parent.parent;
    return null;
function(mapName, sel)
var map = GetParent().Fusion.getMapByName(mapName);
GetParent().SetSelectionXML(sel);
The one issue I did run into is that when grabbing the selectionXML
selectionXML = selection.ToXml();
the XML was incorrect...For the layername it was bringing in only the second part of the layer name (i.e. Parcels instead of Default:Parcels) which was giving an error in fusion when setting the selection.   For right now, I am just replacing the string after calling selection.ToXML
There is also a setSelection() function in fusion, but I haven't tried it yet...
Thanks,
Brian  Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of foolfish
Sent: Sunday, June 08, 2008 10:17 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] how to set selected feature at client in fusion???
my problem is in tradition method (not use fusion), i can select feature at
server, and display the selected feature at client。
but in fusion,the follow line is failed:
parent.parent.SetSelectionXML(selectionXML);
parent.parent.mapFrame.Refresh();
my question is how to setSelection at client in fusion?:confused:
[at server]:i define a function to select Feature,and return a selectionXML
public void CreateSelectionXML(String queryLayer, String queryString,String
map_name)
        MgResourceService resService =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
        MgFeatureService featureService =
(MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
      MgMap map = new MgMap();
        map.Open(resService, map_name);
        MgLayer layer = (MgLayer)map.GetLayers().GetItem(queryLayer);
      MgResourceIdentifier resId = new
MgResourceIdentifier(layer.GetFeatureSourceId());
        MgFeatureQueryOptions queryOption = new MgFeatureQueryOptions();
        queryOption.SetFilter(queryString);
        MgFeatureReader featureReader = featureService.SelectFeatures(resId,
queryLayer, queryOption);
      MgSelection selection = new MgSelection(map);
        selection.AddFeatures(layer, featureReader, 0);
        OutputSelectionInHTML(selection, featureService, queryLayer);
[at client]:
    string sessionID = Request.Form.Get("SESSION");;
     String queryString = "ID='"+ Request.Form.Get("ID"); +"'";
     String queryLayer =  Request.Form.Get("LAYER_NAME");
     String map_name = Request.Form.Get("MAP_NAME");
     InitializeWebTier(Request);
     onnectToServer(sessionID);
     CreateSelectionXML(queryLayer,queryString,map_name );
     String selectionXML = utility.SelectionXML;
<script type="text/javascript" >
        function onPageLoad() {
            var selectionXML = '<% = selectionXML  %>';
</script>
<body onload="onPageLoad()" >
</body>
View this message in context: http://www.nabble.com/how-to-set-selected-feature-at-client-in-fusion----tp17725343p17725343.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080609/afb56c42/attachment.html
