[mapguide-users] how to set selected feature at client in fusion???
foolfish xjimmyshcn at sohu.com
Tue Jun 10 00:55:48 EDT 2008
oh~ it brought new problems:
the first time i select the feature , it's quite normal.
but it's abnormal after i make a new selection.
how to clear the previous selection?
Paul Spencer-5 wrote:
> Hi,
> Fusion works with selections somewhat differently, you should be able
> to just save() the selection on the server side and Fusion will pick
> it up (at least that is how the query stuff works).
> I believe Mike did add something for selection xml but I don't know
> what it was - perhaps he will comment :)
> Cheers
> Paul
> On 8-Jun-08, at 10:17 PM, foolfish wrote:
>> my problem is in tradition method (not use fusion), i can select
>> feature at
>> server, and display the selected feature at client。
>> but in fusion,the follow line is failed:
>> parent.parent.SetSelectionXML(selectionXML);
>> parent.parent.mapFrame.Refresh();
>> my question is how to setSelection at client in fusion?:confused:
>> [at server]:i define a function to select Feature,and return a
>> selectionXML
>> public void CreateSelectionXML(String queryLayer, String
>> queryString,String
>> map_name)
>>        MgResourceService resService =
>> (MgResourceService
>> )siteConnection.CreateService(MgServiceType.ResourceService);
>>        MgFeatureService featureService =
>> (MgFeatureService
>> )siteConnection.CreateService(MgServiceType.FeatureService);
>>      MgMap map = new MgMap();
>>        map.Open(resService, map_name);
>>        MgLayer layer = (MgLayer)map.GetLayers().GetItem(queryLayer);
>>      MgResourceIdentifier resId = new
>> MgResourceIdentifier(layer.GetFeatureSourceId());
>>        MgFeatureQueryOptions queryOption = new
>> MgFeatureQueryOptions();
>>        queryOption.SetFilter(queryString);
>>        MgFeatureReader featureReader =
>> featureService.SelectFeatures(resId,
>> queryLayer, queryOption);
>>      MgSelection selection = new MgSelection(map);
>>        selection.AddFeatures(layer, featureReader, 0);
>>        OutputSelectionInHTML(selection, featureService, queryLayer);
>>        selectionXML = selection.ToXml();
>> [at client]:
>>    string sessionID = Request.Form.Get("SESSION");;
>>     String queryString = "ID='"+ Request.Form.Get("ID"); +"'";
>>     String queryLayer =  Request.Form.Get("LAYER_NAME");
>>     String map_name = Request.Form.Get("MAP_NAME");
>>     InitializeWebTier(Request);
>>     onnectToServer(sessionID);
>>     CreateSelectionXML(queryLayer,queryString,map_name );
>>     String selectionXML = utility.SelectionXML;
>> <script type="text/javascript" >
>>        function onPageLoad() {
>>            var selectionXML = '<% = selectionXML  %>';
>> </script>
>> <body onload="onPageLoad()" >
>> </body>
>> View this message in context:
>> http://www.nabble.com/how-to-set-selected-feature-at-client-in-fusion----tp17725343p17725343.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/how-to-set-selected-feature-at-client-in-fusion----tp17725343p17747778.html
