[mapguide-users] Problems with Studio 2009 API
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Jun 9 10:35:49 EDT 2008
You might get responses here, but MapGuide Studio is an Autodesk product,
and has its own forums at the Autodesk site.
I think this is the place, but I'm not sure:
http://discussion.autodesk.com/forum.jspa?forumID=233
Regards, Kenneth Skovhede, GEOGRAF A/S
Tanja Suikkanen skrev:
> Hi,
> I need to use the Autodesk Mapguide Studio APi but I'm unable to get
> it work in Visual Studio 2008. Studio and all other functionalities
> are working fine.
> I've added the references in my project
> (Autodesk.Mapguide.Studio.Load, ...Studio.Site and ...Studio.Dwg.Load)
> and the installation path of Studio in to path variable but still I
> get the following error: The specified module could not be found.
> (Exception from HRESULT: 0x8007007E). I think this is an aspnet error
> but I'm still asking you. Maybe someone has had the some problems...?
> --Tanja
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080609/6342d087/attachment.html
